Repairs = $$ ?
Old Oct 20, 2006 | 12:51 AM
magneticmike's Avatar
magneticmike
Default Repairs = $$ ?
I'm thinking about an extended warrantee for my 2000.
Can any of you members shed some light on how much it cost you for your repairs? Or is the GM guide that the Service Dept. uses (to estimate time for repairs) listed on the web anywhere?
Old Oct 20, 2006 | 01:32 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Repair a power seat module, fix the drivers side rocking seat, and lubricate the drivers side rear axle spline = 1596.00
My cost = 0.00
Old Oct 20, 2006 | 08:42 AM
DeeGee's Avatar
DeeGee
My one claim through GMPP
EBCM invoiced at $1350 and I paid the deductable.
Old Oct 20, 2006 | 10:43 AM
patton's Avatar
patton
St. Jude Donor '09
i got ext. for my 01 about a year after i got it [new] 6/60k no deductable i think just under 2k .a few things were warr. 2k worth? no . insurance is a gamble do ya feel lucky well do ya
Old Oct 20, 2006 | 12:58 PM
5W0P3's Avatar
5W0P3
3-4 shift fork broke.
i still haven't figured out how much it cost me. but no warranty. rebuilt it so it wouldnt' happen again, and also replaced the clutch since the tranny was coming out.
Dual Disc Mcleod & Adjustable Master Cylinder
Mcleod Aluminum flywheel
Viper Internals for my t56
LPE hardened output shaft
some seals on the rear fixed
labor
think i dropped about $3500 on everything.
My EBCM went out. Fixed it for $281.
I have a problem right now with a steering sensor. Sensor is $65 but the install is pretty indepth with removing the steering column. It'd be nice to just give it to a dealership and say "fix it"
Old Oct 20, 2006 | 01:42 PM
On my first extended warranty, I had the seal between the tranny and the differential go bad. Cost $650 to repair - all it was is a silicone gasket - labor was the rest. My cost was $0 under the warranty.
Current extended warranty - had a fob go bad - Warranty Direct picked up the tab - $124 for the part, $64 labor. My cost - $0.
Old Oct 20, 2006 | 01:53 PM
aaavette's Avatar
aaavette
The factory warr. covered my rear diff. seal replacement.
To replace the fuel pump & fuel sensor was $1,750, ext. warr. covered it all, including towing.
Old Oct 21, 2006 | 11:11 PM
magneticmike
Thanks for the replies. Any more out there?
To Repairs = $$ ?
