Headlight cover alignment
Old Oct 23, 2006 | 11:45 PM
MAC5's Avatar
MAC5
Default Headlight cover alignment
Anyone know the secret to aligning the head light cover ? My 98's headlamp assembly was replaced back in 2004 and top cover alignment has been off since that repair. The misalignment I'm refering to is the gap measurement between the fender, front facia, and hood. Its the gap tolerance in a couple of areas thats off. As for being flat with the hood fender and facia surfaces its fine. Is there some adjustment that can be made to the whole assembly? It looks like a simple adjustment, I need to move it slightly back and toward the center of the hood about 1/8 inch. No biggie, just one of those things that I want to fix now that its getting colder outside.
Old Oct 24, 2006 | 12:07 AM
BeechBoy's Avatar
BeechBoy
I adjusted mine a couple of weeks ago. It is a simple job but requires patience. From what I recall, you need to remove the cover off the headlight assembly. it is held in place by four screws; two at the back and one on each side (don’t forget to remove first the wraparound black plastic piece) . Once the cover is removed you will expose its mounting structure . The mounting structure is attached with screws to the remainder of the headlight assembly. Those are the screws that allow the lateral adjustment. I played with those to set mine in the proper position.
Good luck
Old Oct 24, 2006 | 01:08 AM
A.Fry's Avatar
A.Fry
hey BEECHBOY i like that forked tail doctor killer, is that your plane
Old Oct 24, 2006 | 05:14 AM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
Pretty much what BeechBoy said.
Once the cover is off, there are little "bumper" like stops (think small hood bumper stops) that can be adjusted.
Old Oct 24, 2006 | 12:59 PM
MAC5's Avatar
MAC5
Thanks to all for the assist. Took about 1/2 hour and all is well. Now to go find something else to fix on it.
Old Oct 24, 2006 | 10:02 PM
BeechBoy's Avatar
BeechBoy
Yep! A bonanza and a corvette is a wonderful combination.
To Headlight cover alignment
