car problem need help !!!!!!
Old Oct 31, 2006 | 07:53 PM
  #41
Gitusum's Avatar
Gitusum
Originally Posted by Gonzo
My heart goes out to you, I know my patience would be wearing thin about now. I say call the dealer, is it still under any kind of warranty??
Sorry I have no good ideas
Gonzo
thanx gonzo believe me ive lost patience with it but i believe its my bcm gone bad and looking for a good used 1 to get so i can see if that solves my problem.i wish i had a warranty!!!!
Old Dec 8, 2006 | 10:04 AM
  #42
aquino's Avatar
aquino
1st Gear
Hi to all,
I have a '98, and yesterterday it start with the same problem. Do some one resolve it? Check if your check engine light is comming on, when you move the ignition switch to the on position. Mine is not. Battery, alternator, stater, fuses, relays are ok
Old Dec 8, 2006 | 10:30 AM
  #43
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Originally Posted by Yello95
Just for the heck of it, try a new battery...just a long shot....
also...see if a ground is loose...
Friend had the same problem on his 01. Battery connection to the starter was corroded and loose. Cleaned it and reconnected it and checked grounds all around and it fired right up.
I had the same problem on my Chevy van except the starter went bad. Smaked it with a wrench and it started. Replaced it and drove it another 100K.
Good luck
Old Dec 8, 2006 | 10:56 AM
  #44
Sure hope you find out what the culprit is soon. I know this can be very frustrating - especially when it is your only car. Let us know what you find.
Old Dec 8, 2006 | 11:41 AM
  #45
T Will's Avatar
T Will
St. Jude Donor '13-'14-'15-'16-'17-'18-'19
Pm Bill Curlee he wrote the stickies in the tech section I'm sure he will help you he is a great guy.
Old Dec 8, 2006 | 03:55 PM
  #46
Gitusum's Avatar
Gitusum
i fixed my problem it was my bcm module that went bad. cost me about a grand in the part and labor at the stealership but its fixed!!!
Old Dec 8, 2006 | 04:47 PM
  #47
Bullet's Avatar
Bullet
Glad to here you are going again - have you seen this thread?
http://forums.corvetteforum.com/show...&highlight=bcm
Old Dec 8, 2006 | 05:02 PM
  #48
Gitusum's Avatar
Gitusum
no i havent seen that thread why is there a list started on bcm issues?
Old Dec 8, 2006 | 05:11 PM
  #49
rpm462's Avatar
rpm462
Glad you're up and running again!!
Old Dec 8, 2006 | 07:51 PM
  #50
2vettes2go's Avatar
2vettes2go
probably a loose connection at the battery terminal. check it.
