Highly doubt its the gas, pull key wait 10, is the tell tail sign of colum lock issue. Even if the dealer fixed it it will still occur.
A4s did have the propblem also, at least until 2000 or 2001.
GL
I had mine replaced not once,but twice at the local dealership.
If your car is stock,you might risk it and have the dealer install it for you...........at least it is free that way
Others on this site would rather install themselves so as not to let the stealership touch their cars.That choice,of course,is up to you....
Reason I say stock is because if you have a custom tune ,they may erase that if they reflash the computer.I think they do that at the dealer in some cases.
Just wanted you to know,in case you didn't,that it is a recall
From: "Never play games with a bitch who can play them better" NE PA
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Flynbya2---recall?? Since I just bought it I know nothing about it. How long has it been a recall and can you give me as much information as possible? Does it have to go to a dealer or can I have my own mechanic do it (I trust him more)? The more you can tell me the better off I will be..If the recall was awhile ago will they still cover it? And if the previous owner did have it done will they still do it again?? Ok---now I have a headache...
Thanks guys---anyone got anything stronger than an aspirin---oh wait--I do---nevermind..
I just had mine done AGAIN on my 98 about a month ago for nada/zilch/zip
I was a lil' surprised it had to be done again actually,I believe there was an "upgraded" version that I didn't get the first time
You should be good to go now.Call the dealer,or buck up and have your mechanic replace it for a fee,and the cost of the part.
Or,save your money.......and send half to me
Tip:just tell them you only want the column lock issue replaced..NOTHING ELSE!!
That way, if it turns out to be something else, you can have it repaired by your mechanic....and the diagnosis of the extra problem will be free! (I love that word )
If your car has not had any of the previous recalls performed on it, I strongly suggest you DO NOT do it. If you do a search on the subject you will find many people who had the recalls done had problems afterwards. The dealers may use a faulty k harness and also program your car to cut fuel if it detects a problem with the column lock whether real or perceived. Somtimes the CLB will not work properly after the recalls have been performed. You can provide your dealership your VIN and they will be able to tell you whether or not the recalls were done to your car. Just purchase the Column Lock Bypass kit and you can install it yourself, it is very easy. Here is a link showing you how.
If you fueled up the evening before with a different fuel than usual chances are that may be the culprit. Had the same problem, removed key for 10 sec, restarted and no further problem. Column lock fixed prior-
Chevron Preimum only-
I think the dealer must do it for the freebie
If I get to save any money it will be put into my mod fund --got tires, wheels and exhaust to think about..
*Edit...BTW, can your steering wheel turn with the key out of the ignition?
It has been quite some time since I have revisited this issue(clb),but if memory serves me,I seem to recall the problems related to dealer installed clb's was with the m6 transmissions and not nso much the a-4's
Which is why I decided to have mine done,and yes it did fail once,but repaired again for free...
Btchn99......If your wheel turns free,you have apparantly had the clb performed
If it is the clb issue revisited( like mine),they will repair and upgrade the harness free of charge
If I were you I would still ask your dealer to run your VIN and see if they performed the recall. If you are lucky they did not perform the recall and the previous owner installed the aftermarlet CLB.
If you do have the CLB installed then that code is probably related to the VATS (Vehicle Anti Theft System). Try cleaning your key (pellet) or try using your spare key and see what happens.
I like free
The column lock issue was prevalent in both the M6 (97-2004) and A4's (up to and including the 2000 models). The initial recall did not remove the locking plate in the M6's as they did in the A4's. The Feb 2006 recall did remove the locking plate in the M6's however they also had numerous problems with faulty K harnesses. IMHO you are better off not having any of the recalls done and just install the CLB.
I like free
If this was done by the person that previously owned the car and not a dealer is it still coverd?? And is the new harness better than this other one that I am reading seemed to be substandard??
Did you remember to bring your crystal ball to answer all my questons tonight??? I might brake it ya know..
BTW: I like free to but your still not getting my savings..
Good advice IHHO
Lori, I have a later model A4 so I'm not affected. That said, there are very few posts of problems after a CLB is installed. On the other hand, horror stories of failed dealer fixes are very common.
When I previously owned a 98 A4, I got the message one time. I cleaned the key and never got it again. There is a third type of C5, one that has never had the column lock in the first place. Good luck, post what happens.
This same thing has happened to me before. I have the clb installed and it is an A4. But anyway...what your problem here is a dirty chip on the key. I posted the same problem here previously and everyone told me that was the answer. I cleaned the key and problems have not returned. Try cleaning it first. Don't panic and start calling Mr Goodwrench right away.
