Clean your udders
Old Nov 19, 2006 | 10:13 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Default Clean your udders
there are 3 udders under the wiper motor, this is one of the reasons wiper motors fail
here's a pic from Billdog350's coupe, H/C, Textralia OZ700, GM Z06 clutch master/slave install, that's the new Z06 master
Old Nov 19, 2006 | 10:51 AM
rws.1's Avatar
rws.1
Yup....
I clean then every fall as part of my pre- hibernation program
Old Nov 19, 2006 | 11:14 AM
tiojames's Avatar
tiojames
Thanks for the tip. Learned something new today.
Old Nov 19, 2006 | 11:44 AM
JWall64's Avatar
JWall64
Thanks!!!
Z06Aggie's Avatar
Z06Aggie
Where EXACTLY are those?
Old Nov 19, 2006 | 01:48 PM
SteveDoten's Avatar
SteveDoten
from the top on a M6 car reach below/outboard of the clutch master cylinder reservoir
Old Nov 19, 2006 | 02:52 PM
Dave1998's Avatar
Dave1998
I think a pic from the top is in order
Dave
Old Nov 19, 2006 | 03:18 PM
Oldvetter's Avatar
Oldvetter
Windshield wipers ! These cars have windshield wipers ? What do you use those for?
Just kidding, I just cleaned out mine. I never knew that. All of mine had leaves, one was wet and slimely.
Old Nov 19, 2006 | 03:38 PM
toxdoc's Avatar
toxdoc
Thanks for the tip! I just found mine, and they'd probably never cleaned before. I couldn't believe the amount of cr@p I pulled out of there.
On my A4: they are about 1.5 inches in diameter, something like 3 inches long. They point straight down. They drain water out of the area that houses the wiper motor/mechanism. Open the hood. They are below and outboard, and slightly aft, of the power brake boost unit (the big black round thing betweeen the brake fluid resoirvior and the firewall.)
I found leaves, twigs, a candy wrapper (??) and I think Jimmy Hoffa's business card, among other things in there.
Old Nov 19, 2006 | 03:56 PM
RTSVET's Avatar
RTSVET
Thanks for the tip i will go check mine now.
Old Nov 19, 2006 | 04:02 PM
Mudlizard's Avatar
Mudlizard
Great Post!!........... Even for us garage queens. I got some udder touchin to do.
Old Nov 19, 2006 | 04:23 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Thanks for the tip! I never knew about those.
I just checked mine and there are only 2 udders. Could that be on a 2002?
Old Nov 19, 2006 | 05:01 PM
jbone's Avatar
jbone
I just checked mine also. All 3 of mine were perfectly clean There are 3 utters just the third one is a little harder to find. You have to stick you hand further towards the driver seat and drivers door to get to the third one. Trust me its there. You guys must have some dirty vettes for those utters to get that dirty
Old Nov 19, 2006 | 05:25 PM
vettman96's Avatar
vettman96
Wow, another cheap thrill from my car. Now, what kind of
bag balm should be applied after cleaning?
Old Nov 19, 2006 | 05:39 PM
jbone's Avatar
jbone
Old Nov 19, 2006 | 05:56 PM
Uncle John's Avatar
Uncle John
HA!, did it today while I was measuring for screens.
Old Nov 19, 2006 | 07:53 PM
Quite a bit of junk in there. Good reminder.
To Clean your udders
Old Nov 19, 2006 | 08:22 PM
oahuyahoo's Avatar
oahuyahoo
What would happen if I was to snip the ends off those so that the zilch will fall through?
Old Nov 19, 2006 | 08:30 PM
blazeone's Avatar
blazeone
There are more on the passenger side.
Patches's Avatar
Patches
The zilch???
