I can't believe the design of these things based on their intended function! It looks like the GM engineers took a low cost design approach to allowing water to drain. Maybe I'm missing something...
True, true. Maybe attach a large plastic tube to each and route it towards the empty volume that is the cove area.
I don't know of course, but if it was low cost, and less than optimal, I'd bet they had that decision made already by someone else as part of the assignment they were given.
Quote:
Originally Posted by oahuyahoo
What would happen if I was to snip the ends off those so that the zilch will fall through?
Small animals (mice) might go through and build a nest in there.
Good point. I once had a '62 Olds that wouldn't start. Diagnosis - rat's nest in the air cleaner housing. Then there's the problem with marmots eating your electrical system here when you park to go backpacking in the high country, but that's another subject.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Thanks Steve
Thank you for the udderly important information.......
Garaged cars are less likely to have as much in their udders as those that are kept outdoors parked under trees.
Through the access panel in the passenger side wheel well and removing the battery and going from the top. The passenger side doesn't have the udders, but instead has a long tube that twists and turns around towards the bottom of the car. Also, while you're in there it's not a terrible idea to check the a/c evaporator drain for debris as well to prevent a flooded BCM.
Just cleaned mine. The front two were not to bad just a little dried leaves. The back one was full of pine straw and dried leaves. Also cleand off my radiator, it was not bad at all.
