Clean your udders
Old Nov 26, 2006 | 03:57 PM
  #61
Freestyler's Avatar
Freestyler
Originally Posted by Patches
Zilch & Dreck - I luv it! We should all be unzilching and dedrecking our udders in the next couple of weeks.
what the frack?
Old Nov 26, 2006 | 06:11 PM
  #62
Chicago's Avatar
Chicago
St. Jude Donor '15
Thanks for the reminder! Two of mine were full of junk. One took a leak on me.
Old Nov 26, 2006 | 06:29 PM
  #63
berryj's Avatar
berryj
Anyone have an answer for my two questions above? That snake pipe on the pass side is a pain to get out/in, I just flushed it from above w/ a hose, but where does it come out? How do u get to the a/c drain ? from below the car?
Old Nov 26, 2006 | 07:27 PM
  #64
napacruzerc5's Avatar
napacruzerc5
Found the driver's side udders with no problem with only one with dried leaves in it. Passenger side is another matter. Will need to turn the vette around in the garage for me to access it. Wife said she had other udders if I was interested; easier to access too.
Old Nov 26, 2006 | 07:44 PM
  #65
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Bill Curlee has a better post over in the C5 tech stickie, it dumps near the bottom of the fender
a/c drain? long screwdriver when the car is on the lift, it's difficult to reach
here's a motorswap we did from last spring, the drain is on the pass. side, pointing 8o'clock
Old Nov 27, 2006 | 03:20 AM
  #66
oahuyahoo's Avatar
oahuyahoo
For your sake I hope it doesn't have as much gunk as I found in mine.
Old Nov 27, 2006 | 08:44 AM
  #67
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Originally Posted by oahuyahoo
What would happen if I was to snip the ends off those so that the zilch will fall through?
I had the same ? and was told by a Vette mech (independent) not to snip the ends off as water can be forced up into them and get to the wiper motor. He said just clean em out every month or so to get the crap out. Also do the AC drain on the passenger side.
He said it is also a good idea to pop them out once a year or so, wash them and apply some good silicone lube to them to keep them from drying out.
Old Nov 27, 2006 | 08:47 AM
  #68
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Originally Posted by Mudlizard
Great Post!!........... Even for us garage queens. I got some udder touchin to do.
Old Nov 27, 2006 | 12:14 PM
  #69
ytwokc5's Avatar
ytwokc5
Don't know about your first question... I haven't cleaned the udders out myself yet.
I was able to yank the A/C drain off from the top, but it is a real PITA to get to. I scratched the heck out of my arm, and had to feel my way around. I have not put my hose back on yet... can't figure out how to! It's been suggested that it's a little easier to get to from the bottom of the vehicle, but almost impossible if you have headers. Def do this when the motor is cool!
Old Nov 27, 2006 | 12:35 PM
  #70
berryj's Avatar
berryj
Thanks ytwokc5 and Steve! I'll try to approach the a/c drain from the bottom w/ the screwdriver technique!
Also, for the passenger side snake, maybe the next time I take the fender well out, I'll take a closer look at the end of it. For now, it seems to be draining when I put water in from the top behind the battery compartment.
Old Nov 27, 2006 | 02:10 PM
  #71
OUR97's Avatar
OUR97
Originally Posted by Paulg680
I can't believe the design of these things based on their intended function! It looks like the GM engineers took a low cost design approach to allowing water to drain. Maybe I'm missing something...
In the late 60's and early 70's GM owned and produced the Frigidaire line of home appliances. On the bottom of the refrigerators was a drain to let the defrost water drain down into the pan. On that drain under the fridge was a rubber item shaped exactly like the Corvette Udders but smaller and they were also called Udders. They were there to let the water out and keep the heat from going back up into the refrig. They were about the size of your index finger and when they needed cleaning it was a very gooey, ugly mess in there. I got a laugh when I saw the title of this post and it reminded me of those good old days when I serviced GM's udders. So it wasn't especially a low cost design but a time-proven design. Any questions class?
Old Nov 28, 2006 | 11:07 AM
  #72
LTaylor's Avatar
LTaylor
Do all Vetts have these? I have an 04 coupe with Auto tranny.
Old Nov 28, 2006 | 10:58 PM
  #73
SteveDoten's Avatar
SteveDoten
interesting story
makes sense with avoiding the heat, the other end of the cowl area is the intake for the HVAC system
Old Nov 29, 2006 | 07:52 AM
  #74
EBZ0602's Avatar
EBZ0602
2015 C5 of the Year Finalist
St. Jude Donor '05-'10
Thanks for the post, I found mine yesterday, but they were clean except a leaf or two
Happy Motoring
EBZ0602
Old Nov 29, 2006 | 01:07 PM
  #75
ytwokc5's Avatar
ytwokc5
All C5 vettes have the udders.... not sure about the other gens.
Old Nov 29, 2006 | 04:34 PM
  #76
Vetteoholic's Avatar
Vetteoholic
Thanks for the Info...& thanks for sharing
Old Nov 29, 2006 | 09:16 PM
  #77
Luv My Vette's Avatar
Luv My Vette
Originally Posted by Tigershark3
Has anyone had one of these udders fall off? When I first got my car I found one on the frame of the car. Had no idea what they were at the time.
I just checked mine and there were only two... The third was at the bottom of the cavern, picked it up and installs real easy. There were not much in the other ones only little bit of dried leaves not too exciting....
To Clean your udders
Old Nov 29, 2006 | 09:40 PM
  #78
Blue Lightening's Avatar
Blue Lightening
This Udder post answered once and for ever the age old question to the argument about if a Vette is a male or female.
Norm
Old Nov 29, 2006 | 09:42 PM
  #79
Tino's Avatar
Tino
My wife said I can't mess with the utters on my vette
Old Nov 29, 2006 | 09:47 PM
  #80
Ta-taaa's Avatar
Ta-taaa
Ok I cleaned my Satuday... And my wife wont talk to me now! I think she's Jealous
By the way.. I had a ton of junk in mine!
