Any C5`s here WITHOUT differential leak problems?
Nov 30, 2006 | 11:12 AM
20K on the 03 no leaks. 30K on the 2000 no leaks.
Nov 30, 2006 | 01:44 PM
My 01 Vert leaked at 12K, repaired at Stealership, $400, no more issues.
Nov 30, 2006 | 01:55 PM
Nov 30, 2006 | 03:04 PM
Quote:
Originally Posted by Yello95
i was under my car aligning my exhaust system.
Nov 30, 2006 | 05:50 PM
rear end leaks
no leaks so far
'04 torch red 3:15 rear
Nov 30, 2006 | 05:52 PM
Nov 30, 2006 | 06:23 PM
Not a drop on the 3.90's, The stock rear attacted dirt to a moist area around the seal but it never leaked.
Nov 30, 2006 | 06:26 PM
No leaks
Nov 30, 2006 | 06:51 PM
St. Jude Donor '08-'09
Quote:
Originally Posted by 81c3
When I got my car it would leave a spot on the garage floor about the size of a nickel.......only after running it pretty good & getting it hot).
One day it just stopped & its been fine since.
Same happened here with my 2000FRC, 14K.
Nov 30, 2006 | 07:23 PM
My ' 04 leaked
My '04 leaked on drivers side of differential. Mine is auto. However other '04's in my car club also had leaks. Replaced seal under warranty. Dealer said this was a known problem. Maybe it's just the '04's.
Nov 30, 2006 | 08:37 PM
St. Jude Donor '03-'26
Nov 30, 2006 | 08:49 PM
Never a leak on my 98 Vert.
Nov 30, 2006 | 09:45 PM
Not a single drop from my '97 w/ 67k Miles!
Dan
Nov 30, 2006 | 10:10 PM
00 with what I thought was a leak, turned out to be tranny damage. Rebuilt (under extended warranty) last month at 65k miles.
Nov 30, 2006 | 10:29 PM
120k ,
1998 ,
2006 ,
c5 ,
corvette ,
differential ,
differentials ,
hot ,
leak ,
leaking ,
mile ,
problems
