Any C5`s here WITHOUT differential leak problems?
Old Nov 29, 2006 | 10:34 AM
  #41
PEW01's Avatar
PEW01
Originally Posted by wisvette
My 2000 coupe does not leave a drop of anything under it!
Same for my 2001 Coupe.
Old Nov 29, 2006 | 10:37 AM
  #42
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
03 modded coupe here with 47K miles. No leaks.
Old Nov 29, 2006 | 11:06 AM
  #43
JohnsC5's Avatar
JohnsC5
65,000 miles and no leaks!
Old Nov 29, 2006 | 11:28 AM
  #44
corvettecrazy2's Avatar
corvettecrazy2
2000 a4 3.15 gears mine's is leaking
Old Nov 29, 2006 | 11:53 AM
  #45
Tigershark3's Avatar
Tigershark3
3.42's w/ 70k and no leaky.
Old Nov 29, 2006 | 12:13 PM
  #46
99 vett babycar's Avatar
99 vett babycar
99, 50K, dry as a bone
Old Nov 29, 2006 | 12:17 PM
  #47
eel's Avatar
eel
111,000 on my o1 and no leaks
EEL
Old Nov 29, 2006 | 12:21 PM
  #48
Jammer's Avatar
Jammer
Cruise-In I Veteran
Cruise-In II Veteran
none on mine...
Old Nov 29, 2006 | 12:23 PM
  #49
ericdwong's Avatar
ericdwong
No issues with leaking from my diff, 112K miles, though I did pull the driveline twice to do tranny and clutch jobs. The transmission- was another matter :ack
Old Nov 29, 2006 | 12:32 PM
  #50
Crash94536's Avatar
Crash94536
2002 Z06, and it leaks so bad I shouldn't drive it until it is fixed.
This is from taking it to the track and driving it pretty hard. The differential and transmission got really hot, this is actually a common problem with Z06s (GM installs transmission coolers on European Z06s, but not on the US versions). I will be ordering differential and transmission cooler kits from Doug Rippie Motorsports which shoud take care of that problem.
These kits are not cheap, not many manufacturers making transmission cooler kits for manual transmissions. GM sells theirs for about $1000, DRM goes for $650 for each for diff and tranny.
I will admit, driving the Z06 on a road racing track was INTOXICATING!
Can't wait until it's fixed and ready to go again.
Old Nov 29, 2006 | 12:36 PM
  #51
b98's Avatar
b98
Two, and no leaks.
Old Nov 29, 2006 | 12:38 PM
  #52
Mine has leaked twice - once at 10.6K miles and than again at 18.8K miles. The last repair seems to have solved the problem at least for now - car has 32K miles on it now.
Old Nov 29, 2006 | 01:36 PM
  #53
Nick1's Avatar
Nick1
No leaks, '04 w/26,000 mi.
Old Nov 29, 2006 | 02:05 PM
  #54
TheBigDog's Avatar
TheBigDog
Not now I just replaced the seal with only 13,000 miles on it
The Big Dog
Old Nov 29, 2006 | 02:30 PM
  #55
CVG323's Avatar
CVG323
Originally Posted by silverhead
Not one drop from my 97!
same here brother!
Old Nov 29, 2006 | 03:22 PM
  #56
C5FORFUN2's Avatar
C5FORFUN2
'01 89,000 miles - No leaks maybe it's empty
Old Nov 29, 2006 | 03:25 PM
  #57
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Y2K w/no leak
To Any C5`s here WITHOUT differential leak problems?
Old Nov 29, 2006 | 04:07 PM
  #58
zipduda's Avatar
zipduda
Mine is a M-6 97, NO LEAKS!
Old Nov 29, 2006 | 04:11 PM
  #59
Logansar's Avatar
Logansar
Default not mine
Mine is sealed as tight as a nun in a convent...
2003 with 7800 miles....
Sgt Paul
Old Nov 29, 2006 | 06:21 PM
  #60
Yello95's Avatar
Yello95
St. Jude Donor '11
'04...not yet
