Any C5`s here WITHOUT differential leak problems?
Old Nov 29, 2006 | 01:14 AM
2blklt4's Avatar
2blklt4
Default Any C5`s here WITHOUT differential leak problems?
Picking up my new `04 MS M6 friday.
Vehicle was inspected by the local dealer and everything was fine.
The service advisor said that there was just a subtle oil trace on the diff but no leak.
Car has 7000 miles.
Do all C5`s leak at diff?.
Anyone here without this problem or how long (miles) before yours started to leak?
Thank you
Old Nov 29, 2006 | 01:23 AM
2KFRC5's Avatar
2KFRC5
Default Anyone here without this problem
Old Nov 29, 2006 | 01:33 AM
DeeGee's Avatar
DeeGee
Mine leaked very early in its life (02 Vert). Drivers side seal but good since.
Old Nov 29, 2006 | 01:39 AM
silverhead's Avatar
silverhead
Not one drop from my 97!
Old Nov 29, 2006 | 01:47 AM
mixermike's Avatar
mixermike
41k on 98 no leaky
Old Nov 29, 2006 | 01:58 AM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
No real leak on my 98 w 38k on it, but I believe there is a vent of some type up there that allows the case to breathe.
Now that can resemble a leak,but it is normal the way I understand it.
There is a seal issue that quite a few c-5's succumb to though
Old Nov 29, 2006 | 02:03 AM
poolhustler's Avatar
poolhustler
So far so good....
'02 with 16K miles !!
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
Not a drop on my 97 either
Old Nov 29, 2006 | 02:22 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
DTE 3.90s no problems here
Stock 3.42s did not leak either
Old Nov 29, 2006 | 02:26 AM
5W0P3's Avatar
5W0P3
Mine was leaking a little bit when i had my clutch replaced, so he put new seals in it.
Cajun99's Avatar
Cajun99
Zero leaks...148K miles.
Old Nov 29, 2006 | 02:52 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by 2KFRC5
Old Nov 29, 2006 | 02:57 AM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Over 61k on an A4 3.15 with no service history of any leaks.
Old Nov 29, 2006 | 03:54 AM
randy814u's Avatar
randy814u
no leak on the 98 with 120 thou. I can't say the same for the oil pressure sender, it was a gusher.
Old Nov 29, 2006 | 06:02 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
stock no problems, 3.42's no problems
Old Nov 29, 2006 | 07:26 AM
Tom/99's Avatar
Tom/99
My 04 is still not leaking at 12,500 miles.
My 99 was leaking at 9,000 miles.
Old Nov 29, 2006 | 07:27 AM
steve8's Avatar
steve8
Nothing on my 04 here.
To Any C5`s here WITHOUT differential leak problems?
Old Nov 29, 2006 | 07:28 AM
illmac77's Avatar
illmac77
CI 7-8 Veteran
CI 8 Car Show Winner
St. Jude Donor '07
no leaks here
Old Nov 29, 2006 | 07:38 AM
wisvette's Avatar
wisvette
My 2000 coupe does not leave a drop of anything under it!
Old Nov 29, 2006 | 07:55 AM
bb609's Avatar
bb609
My '03 leaked a bit recently but turned out to be coming out of the air vent. Drain out a bit, no more problem.
