Any C5`s here WITHOUT differential leak problems?
Old Nov 29, 2006 | 07:59 AM
INaband's Avatar
INaband
CI 7-8 Veteran
Originally Posted by silverhead
Not one drop from my 97!
.....me either, not heard of this much that I remember from the '97 guys here.
Old Nov 29, 2006 | 08:00 AM
jimbosr's Avatar
jimbosr
04 32000mi no leaks
Old Nov 29, 2006 | 08:07 AM
FinnZ06's Avatar
FinnZ06
No leaks on my 03 either..
Old Nov 29, 2006 | 08:13 AM
Calif Vetteman's Avatar
Calif Vetteman
03 Convertible. Leak appeared at 3100 miles, just this past year. The three year warranty was just up, but I had the extended warranty. Repair was done at Rydell in Northridge CA.
Old Nov 29, 2006 | 08:15 AM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
So far so good here with about 42K miles.
Old Nov 29, 2006 | 08:19 AM
Roostertail's Avatar
Roostertail
St. Jude Donor '06
No leaks on my '04 with 15K
My wifes '03 leaked at 6K, but nothing since with 11K now.
Old Nov 29, 2006 | 08:33 AM
istsme98's Avatar
istsme98
Originally Posted by steve8
Nothing on my 04 here.
Old Nov 29, 2006 | 09:07 AM
81c3's Avatar
81c3
When I got my car it would leave a spot on the garage floor about the size of a nickel.......only after running it pretty good & getting it hot).
One day it just stopped & its been fine since.
Old Nov 29, 2006 | 09:22 AM
NCSU SEE 5's Avatar
NCSU SEE 5
From: Greensboro, NC "REALITY IS MERELY AN ILLUSION, ALBEIT A VERY PERSISTENT ONE"...ALBERT EINSTEIN"
St. Jude Donor '05-'06-'07
04 A4 and not problems to date.
Old Nov 29, 2006 | 09:27 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
My mom's '99 C5 vert mn6 has never leaked since we bougt it and my dad's '04 Z16 Z06 hasn't dripped yet, but my '01 has had to be fixed 2x... but it's been problem free for a few years now.
kromberg's Avatar
kromberg
None here. Even with a rebuilt 3.90 diff
Keith
Old Nov 29, 2006 | 09:28 AM
richieice's Avatar
richieice
My 98 vert was overfilled and was leaking out the vent as well. Put the car up on stands, level it out see if the diff is overfilled. There is a vent on the drivers side all the way up on the top. From what I have read, if it is not the size of a tablespoon there is not much to worry about. Mine used to randomly leak and only about the size of a pea. Once drained the excess out, it stopped. Try that first. Then look at the axle then side cover of the diff.
Old Nov 29, 2006 | 09:33 AM
  #33
Omega Man's Avatar
Omega Man
From: I speak the truth. Harsh but accurate. The Woodlands Texas
St. Jude Donor '09-'10
My 04 started to leak around 3500 miles. It was leaking for a few weeks before I noticed it. Not a drip but just enough to get the bottom of the rear suspension dirty.
Old Nov 29, 2006 | 10:04 AM
  #34
jovette's Avatar
jovette
No leak on my 2000, but I have just 17,000 miles.
Old Nov 29, 2006 | 10:10 AM
  #35
LTaylor's Avatar
LTaylor
04 no leak
Old Nov 29, 2006 | 10:15 AM
  #36
waupachino's Avatar
waupachino
No leaks in my 2.73 rear diff, switched to a 3.42 Z06 rear diff and still no leaks. 22,400 miles total, only about 1000 miles on the new diff.
Old Nov 29, 2006 | 10:21 AM
  #37
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
'98 w/ 60K and no leaks! Zuti
To Any C5`s here WITHOUT differential leak problems?
  #38
jrprich's Avatar
jrprich
No leaks so far
Old Nov 29, 2006 | 10:22 AM
  #39
jrose7004's Avatar
jrose7004
I haven't had any trouble.
Old Nov 29, 2006 | 10:23 AM
  #40
burbleflyer's Avatar
burbleflyer
St. Jude Donor '08
