[Z06] Stock height = Good weight transfer
MD
...Glad you enjoyed yourself and didn't break your Z...
More Even Weight Dstribution during turns = better traction at the tires
and a more balanced feel during hard cornering.
But... how about going thru a turn at the limits of adhesion both front and rear. You are at the turn exit and want to nail the throttle.
Don't forget... you're still at the limit of tire adhesion. Do you want to nail the throttle, have the weight transfer off the front and add to the rear which either:
A) Causes the front to break loose and your car plows ahead so you have to lift the throttle and hope the front tires grip again before any obstacles come up. Believe me, this ain't fun.
B) The additional load transfered to the rear tires causes them to lose traction and you have to lift the throttle and counter the oversteer.
Lowering doesn't have anything to do with the 'stiffness' of the suspension however.
That's all in the 'spring rates'.
The roll stiffness in cornering is the sum of the spring stiffness effects, the sway bar effects, and finally the geometry (ie roll center) effects. The contribution to roll stiffness of the geometry, is esesentially the height of the roll center with respect to the cg. If you lower the car you lower the cg by a specific amount, essentially how much you lowered the car (less the effects of the unsprung mass, which in this case we will ignore). But also the roll center can drop, and in some cases (depending on geometry) it can drop a lot more than the reduction in cg height caused by the lowering. If the roll center drops more than the amount of cg height change, you actually loose effective roll stiffness. That is, the roll center will be lowered more than the CG height change. This effectively reduces the roll stiffness of the suspension due to geometry, and while the springs and bars can still dominate, it can negate some to the good effects of lowering.....If the roll center drops more at one end than the other (again dependent on geometry), then you can and will change the balance of the car. This is one of the reasons why some of the best racing shops aren't slamming our cars to the limit of the stock bolts, they have found that the cars are faster lowered, but not that low...
Whats the diff of 04 shocks vs 02 or 03 shocks
Great pics
Great pics
That is for sure. I had to raise my car UP when I put on the aero body parts for high speed stabilty.
You guys can keep your vettes stock height if you like and go 4 wheeling on the weekends with them...i prefer to be able to haul *** handling with it 3/4" lowered vs any kind of drag launch advantage (which is very little as most of you guys dont have drag racing suspension setup on your Vettes).
Great pics
lol
