Right tire sensor Problem
Old Dec 9, 2006 | 08:45 PM
new1252b's Avatar
new1252b
Cruising
Default Right tire sensor Problem
I changed my oil and both front O2 sensors today. While taking it for a test drive after completion the dic said that my right front tire was flat? I stopped and check the pressure and it was fine. I checked the dic again and I was not getting a right front tire pressure reading. All of the other tires were showing the correct readings. When I got home and shut the car of the dic said somethong like manual tire something??
Has anyone come across this before? I have done a search, but couldn't find any write ups on it? Thanks John
Old Dec 9, 2006 | 09:20 PM
87SAM's Avatar
87SAM
I guess the 1st thing to do is, try reprograming the sensors. If that does not work, well, try to look for something you broke while you were under the car.
Old Dec 10, 2006 | 12:12 AM
rrichar2591's Avatar
rrichar2591
I'm sure I've read instructions on how to reprogram the sensors. You might try to do a search on the subject and see if anything comes up.
One thing to be aware of: It usually takes a few minutes after putting air in the tires for the sensor to update and have it show on the dic.
Old Dec 10, 2006 | 01:15 AM
C5 Z16's Avatar
C5 Z16
Default Sensors
How old is your car? The sensor could have a dead battery.
Old Dec 10, 2006 | 04:36 AM
DeeGee's Avatar
DeeGee
I could be wrong but I think the way the system works is that each sensor transmits the pressure to a central unit which is then displayed. If so, one sensor going out suggests its a local problem to that sensor. The life of the battery is supposedly 5-7 years so it could be coincidental that it failed at the same time you did the other work.
The only option I know of is to reprogram the sensors. If that doesn't work it'll be a sensor change. BTW they are specific to certain model years so make sure you get the right one (forgive the pun)
Old Dec 10, 2006 | 04:44 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
97-00 are different than 01 and up. I bet its a dead battery
Old Dec 10, 2006 | 07:31 AM
Try to reprogram your sensors and see if it comes back online. If not, then it may be a dead sensor and replacement may be in order.
Old Dec 10, 2006 | 10:34 AM
new1252b's Avatar
new1252b
Cruising
Thank you, I will try these suggestions today and will post the results. Thanks ohn
Old Dec 20, 2006 | 11:03 AM
new1252b's Avatar
new1252b
Cruising
Thanks for all your help. I reset the sensor and all is working again.
To Right tire sensor Problem
