Slamming Hood
Old Dec 16, 2006 | 05:37 PM
zonsolo's Avatar
zonsolo
Originally Posted by TomZ
What on earth could you crack??
Maybe when it warms up I can take pictures and show you what happens after repeatedly "slamming" your hood shut.
Mine has been repaired were the two layers of the hood (inner and outer) had started to come apart from the previous owner slamming it shut.
PS: I can drop mine from about a foot and it will latch. I just choose not to after seeing how it had injured my hood.
Old Dec 16, 2006 | 05:44 PM
Rhode Warrior's Avatar
Rhode Warrior
Not to hijack, but, Zonsolo, what kind of rims are those, they look good.
Big-Red's Avatar
Big-Red
St. Jude Donor '06-'07-'08-'09-'10,'13-'14
Originally Posted by cbx1047cc
So did you adjust it yet? J/K.
Not Yet, it's covered in the Garage and It's dark here so will adjust it tomarrow. (Bad lighting in Garage) But thats a seperate project.
Thanks. C.J.
Old Dec 16, 2006 | 05:46 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
No problem with mine! But if for some reason I don't get it on the first try I just go over and push it down!
Maybe just a little lube(grease) on the pin will do!
Thanks,Matt
Old Dec 16, 2006 | 06:33 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by Rans98
I completely agree Works perfect
Same here...I have never yet let mine drop to close...one small push on each side and bingo
Old Dec 16, 2006 | 06:37 PM
TJ VETT's Avatar
TJ VETT
My aftermarket hood has two small stress cracks right above the latches from pushing the hood down!
Old Dec 16, 2006 | 08:44 PM
zonsolo's Avatar
zonsolo
Thanks, SSR GT3's
Old Dec 17, 2006 | 12:50 AM
Choreo's Avatar
Choreo
On previous Corvettes I have had stress cracks develop from having mechanics/Avis Lube, etc. press down on the corners and I prefer not to touch the paint if I can help it.
On my C5 if I take my thumb and index finger and position them right in the center of the back ridge of the hood and gently push it from about a height of 6-8" it always closes. If I try the same technique holding the hood anywhere but in the middle one latch will try to engage too soon leaving one to push down. I also find I have better luck if I grab the hood with my right hand while on the passenger side of the car - works 100% of the time for me.
Old Dec 17, 2006 | 12:54 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
As mentioned... no need to slam... I never do. Lay down then press on each side over the latch.
Old Dec 17, 2006 | 01:06 AM
KHM_70's Avatar
KHM_70
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Originally Posted by StuzVette
Slam the hood
adjust or press firmly...
got that right, Stu
Nice hood, BTW
Old Dec 17, 2006 | 04:42 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
DON'T slam you hood... its not necessary, and you could crack something.
Here's what I do:
1.) Lower hood all the way down.
2.) Take your palm and gently push down on your hood directly over the retaining clip for the latch on the hood until you hear it "click".
3.) Repeat for other side.
TIP: You can use a microfiber if you are worried your hands are too oily or whatnot.
My hood has never been dropped or slammed.
Old Dec 17, 2006 | 06:44 AM
Properly adjusted, the hood shold latch easily if dropped from about 12". The adjustment mentioned above should allow your hood to close like it should.
That said, I too just lower mine down and then push down on the latch area on each side.
Old Dec 17, 2006 | 09:42 AM
  #33
TomZ's Avatar
TomZ
I can understand how you are gun-shy about dropping your hood after your experience.
However, I think slamming a hood from all the way up (is that what the previous owner did?) vs. dropping it from about a foot are as different as comparing apples and oranges. I still can't believe that a hood can get damaged by dropping it from about a foot up. But you have gotten me thinking about revising my technique, though..
Old Dec 17, 2006 | 01:29 PM
  #34
Big-Red's Avatar
Big-Red
Thanks cbx1047cc, adjusted as per your specs (3 turns) down on the adjustment nut and all is ok now. Both sides of hood latch properly when dropped from about a foot. Again thanks!!
Old Dec 17, 2006 | 05:09 PM
  #35
WvCorvette's Avatar
WvCorvette
Old Dec 17, 2006 | 05:20 PM
  #36
jay'szo6's Avatar
jay'szo6
I usually drop mine from about a foot, then if it doesn't close all the way i'll push down directly above the latch.
Old Dec 17, 2006 | 07:48 PM
  #37
Jet-Jock's Avatar
Jet-Jock
Here's what I do:
