This can't be normal - Help !!
Old Dec 17, 2006 | 08:29 AM
testpros's Avatar
testpros
Default This can't be normal - Help !!
Ever since I did my H/C package I noticed that my exhaust pipes get covered with some black residue whenever I take it for a ride. I never knew how much residue was coming out till I backed the car in the garage and then started her up one morning. This can’t be normal, can it? Should I be concerned? Is there anything I can do to minimize this? FYI, the residue seems to be more carbon like than oil like, and I don't seem to be burning oil.
Old Dec 17, 2006 | 08:34 AM
Roostertail's Avatar
Roostertail
St. Jude Donor '06
Is there any smoke? I'm thinking you are running very rich. I did a H/C over the summer, but I don't have anywhere near that much residue.
Someone more knowledgable will chime in, good luck
Tigershark3's Avatar
Tigershark3
It could be moisture in your exhaust mixing with the exhaust soot then getting blown out when the engine is started. If I wash my car then move it I'll see some of that. .02 deposited.
Old Dec 17, 2006 | 08:40 AM
1badc5GoStrong's Avatar
1badc5GoStrong
Default Same Issue Here
My car has done the exact same thing since DTE did the H/C package on a my new LS2. I put a catch can on it and that cought some oil but the problem seems to be under high HP applications there is PCV blow by where oil froth gets into the intake. Take your intake off and I promise there will be oil in it. I run 442 RWHP and 440 RWTQ and I now have 12K hard miles on it and it runs great, I just have to clean the back of the car alot. There are many post on this and apparently this is a design defect of the small block. Run a query on "catch can" and you will see a pleathra of discussion on this topic.
Old Dec 17, 2006 | 08:52 AM
testpros's Avatar
testpros
Does anyone know if oil in the intake is harmful, or is this just the nature of the beast and I'll have to live with it? What I have read about catch cans seems that they only catch 'some' of the oil. Are they even worth it?
Old Dec 17, 2006 | 09:00 AM
oldschoolvette's Avatar
oldschoolvette
Have you had a good tune put in the car? It looks like a rich condition is causing soot build up and the moisture brings it out the pipes. The reason you didnt see it before is you are moving a lot more air now. A catch can is a good idea but I would look into a quality tune. And yes there is a huge difference in tuners. There are much fewer quality guys than you might think. Good luck
Old Dec 17, 2006 | 09:08 AM
vettes4fun's Avatar
vettes4fun
I had LGM tune my car and I still have a little soot.
Old Dec 17, 2006 | 09:44 AM
testpros's Avatar
testpros
I had ECS do all my work (including the tune).
Old Dec 17, 2006 | 09:49 AM
TomZ's Avatar
TomZ
Same thing happens to me.
Old Dec 17, 2006 | 10:28 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
I have the same issue, started with long tubes & hi flow cats
Old Dec 17, 2006 | 10:47 AM
C5 KIDD's Avatar
C5 KIDD
Cruise-In VI Veteran
guys... its exhaust, its going to be black and sooty. you cant judge a car being rich because of that. when moisture builds up in the exhaust it mixes with the soot and blows out the tail pipes when the car is started!
no big deal
Old Dec 17, 2006 | 10:59 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are different aspects of tuning. You can tune a car for POWER and if you don't go back and adjust the LTFT's for normal everyday driving it can run RICH or LEAN under normal cruising conditions. Adjusting the LTFT isn't something your going to nail down on one tuning test drive. You may get lucky and get close. Most shops cant invest the time necessary to fine tune them so that there very close to perfect. I have spent hours and hours TWEAKING my MAF with EFI Live and I have it very close to where it needs to be. My exhaust tips use to be nasty black and sooty. Last weekend I scrubbed them out and I checked them this morning. They are still clean with only a little brown residue inside them!
BC
Old Dec 17, 2006 | 01:50 PM
testpros's Avatar
testpros
Thanks for all the replies guys. Much appreciated. Sounds like nothing to worry about. It's a beautiful day here in Virginia (nearly 60 degrees). I'm going for a ride to blow out some more soot...
Old Dec 17, 2006 | 03:45 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
There ya go! Drive it... clean the pipes when you get home
Old Dec 17, 2006 | 03:50 PM
hotwheels57's Avatar
hotwheels57
When the weather warms up in the spring and you have an opportunity to drive the car for longer distances rather than just short trips or idling, you'll notice much of the carbon spotting will disappear. It's normal and more noticeable during the colder months.
Old Dec 17, 2006 | 04:14 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Mine got worse after the cam install also. I just keep old floor mats beneath the pipes when it's warming up in the garage.
Old Dec 17, 2006 | 08:30 PM
RonJ's Avatar
RonJ
no big deal
My stock 2001 does just that. I've always considered it normal, I mean, 30mpg cruising at 70mph, things can't be too rich ...
RonJ ...
To This can't be normal - Help !!
Old Dec 21, 2006 | 04:55 PM
1badc5GoStrong
After the car has been run for a while would the soot burn off? I was all over the "rich" issue but surmised no given the performance and very good MPG. I have confirmed oil in intake and many have confirmed this on the site. Could oil in the intake cause this affect?
Old Dec 21, 2006 | 06:33 PM
Honez's Avatar
Honez
To start with the problem you discribed is all tune related. Your running pig rich from what I see. Not uncommon after the H/C install. If you scan the car you will see that your L-Trims are probably way off. Get a tune and have them bias it just a tad lean and your problem will be fixed. If you were in So Cal I could fix it for you in about an hour or so.
Old Dec 21, 2006 | 06:51 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Considering ECS did all the work you dont have to worry about tuning at all. I would call ECS and ask them if you could pour some GM Top End Cleaner over night and blow it in the morning.
