My fob has a passive entry,,, guess this cover would not be good ..?
Read my post a few back. They will work fine on the Early Fobs.
Only problem would be if you switch the Passive Switch on and off regularly. If you leave it on or off no problem.
Barrier
Can this be true!? If so, I will order right away!
BTW, it would probably lessen the possibility of tearing your new key fob cover if you warm it up with a hair drier before installing it on your fob. (Be careful not to get it too hot as that would damage it. Warm not hot) A little trick I learned in the sign business some years ago. Rubber and vinyl products are more forgiving when warmed-up prior to working with it. Heat also comes in handy when trying to remove anything that has been installed with glue as the heat softens up the glue and makes it easier to remove a glued item.
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by Wildcat99
Anyone who hasn't bought anything from Southern Car Parts should know that they are as good as it gets as a vendor. Jim is a class person and runs a A+ company.I Look forward to many future purchases. Thanks Jim!
I with everything you said great company and jim is soooooo nice.
Got the protectors in the mail yesterday. All went on without any problems using the inside-out method. Thanks for bringing us great products sans the Vette tax!
Just installed mine. Thanks to the "inside out" instructions, they went on without any problem at all. Cannot find a way however to reinstall the small keyring, so I just tossed it. Great product for 5 bucks.
Just got the 6 that we ordered in different colors installed. We have an 01 Suburban, 96 Eldorado, and a 98 Vette. The covers fit great, even on the 98 FOB with the passive switch.
Now we don't have to fish for keys anymore. Also no more FOB knocking noise on dash of the 98.
Got my two key fob protectors yesterday and love them.Had no problem putting both on did not even have to use the inside out method to get them on my key fobs only took a few seconds to get them on and they look great.
Received mine yesterday, along with some other goodies, FOB worked great, install the taillight seals today, 2 great products. Jim does it right everytime, Thanks.
PS. Jim never sleeps, has no life and spends way to much time on the computor keeping his customer happy
Glad you like them and thanks for posting the nice words...
