Acceleration Lag
Old Dec 21, 2006 | 08:55 PM
BUSMAN C6's Avatar
BUSMAN C6
Default Acceleration Lag
99 just got 2 weeks ago was wondering does anyone else floor your car from stop and get a lag before the motor revs fully and powers car
seems to be fine in higher speeds from 70 to 80 for instance.
Thxs only been here few weeks and i have emjoyed and hoped learn from all the post here!
Old Dec 21, 2006 | 08:58 PM
Arcane1's Avatar
Arcane1
Supporting Tuner
Cruise-In VIII Veteran
St. Jude Donor '06-'07
That means you got 2.73 gears. They suck. I still have mine but I am looking at some 3.42s in the near future.
Old Dec 21, 2006 | 09:45 PM
Dave68's Avatar
Dave68
I think I know what you mean. When I had my fully stock C5 dynoed (back in 02), there was a slight hiccup that you can see on the chart. It doesn't seem to hurt anything and also doesn't seem to happen all the time.
Old Dec 21, 2006 | 11:18 PM
rgtkst's Avatar
rgtkst
throttle by wire verses throttle by cable!!!!
torque management!! not letting you break things. at least thats what it thinks. it will do this when ever it wants too. these have a little electric motor that opens the throttle body. rather than a actual cable attached to the gas pedal doing it mechanically
i dont like throttle by wire. but i got used to it. i see you have a avalanche in your avatar. it also could have the same type throttle unit. for sure if it is a 8.0L huge block. the ultimate of the line lag mobile with huge power. just unable to use its full potential right out of the gate.
Old Dec 22, 2006 | 12:05 AM
Cole's Avatar
Cole
Could be Traction Control. After I added CAI. New intake maifold, 80MM TB; headers and cat back, mu car hesitated. I turned off TC and the problem went away.
Old Dec 22, 2006 | 12:13 AM
Dave68's Avatar
Dave68
Good point! All that torque tends to kick it in at times.
Old Dec 22, 2006 | 01:40 PM
BUSMAN C6's Avatar
BUSMAN C6
Default ttt
ttt
Old Dec 22, 2006 | 01:42 PM
Herringchoker's Avatar
Herringchoker
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
Might try a new fuel filter, need to replace every 30K.
Old Dec 22, 2006 | 02:36 PM
JH's Avatar
JH
You didn't say whether the car is a manual or automatic. The autos (I have and thoroughly enjoy one) will dial back the timing just a bit to protect the transmission. I imagine the manuals do the same thing, but perhaps they dial back a little less? I have learned to roll on the power rather than nailing it. The car moves out of the slot much quicker.
Old Dec 22, 2006 | 02:42 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Old Dec 22, 2006 | 03:31 PM
BUSMAN C6's Avatar
BUSMAN C6
Default A4
i have found that to be true thxs
Old Dec 22, 2006 | 06:28 PM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
Get a predator or other programmer and turn off the torque management
Old Jan 5, 2007 | 09:03 PM
waventure1's Avatar
waventure1
Default Ttt
TTT
To Acceleration Lag
