trunk release
Old Dec 30, 2006 | 04:25 PM
80vetla's Avatar
80vetla
Default trunk release
When i hit the trunk release the lock disengages but the lid dosent pop up so i have to grab the edges and pull up . Is that normal?
Old Dec 30, 2006 | 04:27 PM
02MillenniumVette's Avatar
02MillenniumVette
It should pop up about 1 1/2" when you hit the trunk release button and then you have to manually pull it up. If it doesnt pop up at all then you need to get it looked at.
Old Dec 30, 2006 | 04:30 PM
80vetla's Avatar
80vetla
Thanks, thought it was funny that its so hard to open!
Old Dec 30, 2006 | 04:59 PM
skillzilla's Avatar
skillzilla
I had a paper bag handle stuck in the lock preventing it from popping up. Take a look in the mechanism for anything foreign.
-_Sf
Old Dec 30, 2006 | 05:12 PM
rogaljr's Avatar
rogaljr
You can adjust it by backing out the rubber stops located on each end of the trunk lid. Turn them out a little at a time, equally, for the minimum that will allow you to open the trunk.
Old Dec 30, 2006 | 05:56 PM
smooth1's Avatar
smooth1
The easiest way to solve your problem is simply to spray some WD40 on the lock/latch mechanism, and voila!
Old Dec 30, 2006 | 06:32 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
The fault I found in mine was that the solenoid released the latch assy. but the latch itself wasn't retracting quickly enough. I did the WD-40 thing and it worked for about a year. This year I am trying the lithium spray grease. So far so good.
Old Dec 30, 2006 | 10:10 PM
Armadillo's Avatar
Armadillo
The WD 40 is the easiest fix, or you can close the door with windows up and it will pop it up. There is also a vendor on the forum that sells a neat little latch that forces up the lid. Don't take it to anyone to look at...they won't have a clue.
Old Dec 31, 2006 | 01:17 AM
abigfoot's Avatar
abigfoot
I see this post every once and a while, it should be in the fix's. What happenes is your latch assembly is loose and dropped. You can tighten it by removing the licence plate assembly and with a extension and 10mm socket loosen it, raise it, and tighten it. works fine afterward.
Old Dec 31, 2006 | 02:00 AM
DeeGee's Avatar
DeeGee
Looks like all the options have been offered. Try the easy ones first. I found that the lube or the rubber adjusters normally fix the problem.
Old Dec 31, 2006 | 02:35 AM
rustyhmt's Avatar
rustyhmt
Must be a Z06. Lotsa posts. I am still dealing with a solutionfor my Z. In one of the posts they do have a retro fit install that pops it up elctrically. Good luck
Old Dec 31, 2006 | 07:36 AM
Not normal. The trunk hatch should pop up enough to where you can get your fingers in there and lift the hatch up.
Old Dec 31, 2006 | 10:56 AM
80vetla's Avatar
80vetla
Thanks For All The Replies! Rained All Day Here Yesterday So Im Gong To Work On It Today! Thanks Again!
Old Dec 31, 2006 | 01:47 PM
Slade's Avatar
Slade
WD40 was my fix! Easiest one to try first! Just be sure to have some rags handy so you don't get it on your carpet.
To trunk release
