jacking points
Old Jan 4, 2007 | 05:55 PM
firstvette99's Avatar
firstvette99
Default jacking points
other than the jacking pucks,what are the other safe jacking points on a 99coupe
thanks
scott s.
Old Jan 4, 2007 | 10:36 PM
donkelso's Avatar
donkelso
Both the front and rear cross members are good locations for a floor jack. You will need a couple of 2x8 sections to put under front wheels to get enough clearance to run a low profile race jack under the front air dam. Use a block of wood between floor jack and cross member.
Old Jan 4, 2007 | 10:52 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Check out these links:
http://www.97vette.com/howto/carlift/index.html
http://www.z06vette.com/diy_lift.php
Old Jan 5, 2007 | 06:30 PM
shannanl's Avatar
shannanl
I use the front and rear crossmembers. Just don't place the jack directly on the crossmember without a strong piece of wood between them.
To jacking points
