Lug nut Torque
Jan 5, 2007 | 08:14 AM
St. Jude Donor '07
Lug nut Torque
Hi, I need to remove my wheels to install splash guards, anyone know the spec on lug nut torque? My car is an '04 with the high-polished rims.
John
Jan 5, 2007 | 08:18 AM
St. Jude Donor '07
Search the sticky at the top of C5 General, should be there... weights, measurements, etc...
Jan 5, 2007 | 08:20 AM
Jan 5, 2007 | 08:30 AM
Quote:
Originally Posted by
steve8
100 lbs
100 ft lbs.
Edit. Use a impact wrench to put them on and tighten to 85-90 then torque down to 100 ft lbs.
I also dont use those chrome capped lug nuts, dont like them. I use some hardened lug nuts I got from napa, about $1.10 each.
But then again, my wheels get beat to chit.
Jan 5, 2007 | 08:59 AM
St. Jude Donor '07
Thank you guys, that makes it simple!
John
Jan 5, 2007 | 09:08 AM
Cruise-In II Veteran
It may be over-kill but I torque to 80 then 90 then 100 in the star pattern.
Jan 5, 2007 | 09:11 AM
100
Jan 5, 2007 | 09:31 AM
2017 C7 of the Year Finalist
St. Jude Contributor
Sully C5
10-4, We usually do that too at the track, but go 60-80-100
Either way is fine I'm sure
Jan 5, 2007 | 09:32 AM
Cruise-In VIII Veteran
St. Jude Donor '07
steve8
100 lbs
Jan 5, 2007 | 06:01 PM
I torque mine down to a final setting of 100 ft/lbs. But, I do it in a progressive fashion - 60, then 80 and finally 100.
dont ever call me that again.
Jan 5, 2007 | 06:14 PM
beefaronie
did I miss something?
Jan 5, 2007 | 07:29 PM
beefaronie
HUH???
