parking
Old Jan 27, 2007 | 04:25 PM
MYZED06_EH's Avatar
MYZED06_EH
Go for the gusto and get yourself one of these. No need for a rear one though because what's behind you is losing.
http://www.save-on-security.com/Wire...a%20System.htm
Old Jan 27, 2007 | 04:30 PM
Frozenfire's Avatar
Frozenfire
I don't recommend backing in because you could hit the pipe tips. I learned by trial and error how long the nose is and then I visualize it when I approach the concrete stop or the curb. My Daytona IROC had the same problem, so I learned from that.
Old Jan 27, 2007 | 05:07 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Originally Posted by TomZ
Practice makes perfect...
I too back in and prefer the curb be on my driver side, so I can crack the door and ensure I don't rub the lip.
Old Jan 27, 2007 | 07:58 PM
RonJ's Avatar
RonJ
Originally Posted by jrose7004
Move forward till you hear the scrape!
Then back-up 6" or so ....
RonJ
Old Jan 28, 2007 | 01:33 AM
Choreo's Avatar
Choreo
This varies somewhat with your height and seat position, but for normal curb/parking-stop height, I find if I glance to the left and look just inside the curve at the bottom of the drivers outside mirror, as soon I see the vertical bend of the curb/stop appear, then the car is positioned just short of the spoiler touching the curb.
The way to determine this for you is to park the car until it just barely touches the barrier (once) then back up slightly and look to the left to see what part of the mirror housing lines up with where the ground and the vertical barrier intersect. That will always put you in the right position until you get a better feel for the car. (Note: this won't work when pulling up next to a wall - just curbs and parking barriers that fit under the nose section.
Old Jan 28, 2007 | 09:53 AM
Bounty Hunter 6's Avatar
Bounty Hunter 6
ALWAYS pull in backwards. More clearance in the back and you don't have to worry about it. That, or take the high heels off while your driving.
Old Jan 28, 2007 | 10:06 AM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by 80vetla
Probably a silly question but here goes. At a parking lot where they have cement curbs that you pull up to is there a trick on how to pull close without hitting it? I always slowly pull up till i think im close then get out . Then i go look so see an like a fool im 3 feet away! AM i the only one that cant park?
What's wrong with three feet away parking spaces that have white lines on either side of them are long enough to park that way (i do)
Old Jan 28, 2007 | 10:16 AM
cjlaw73's Avatar
cjlaw73
I find the nicest most expensive car to park next to, and use the length of that car to judge how close I am. I have also learned that when parking in a lot with a wall in front of you, popping up the head lights give you a good idea how close you are. I don't back in because hitting the pipes could cause more demage than you can imagine. Unfotunately practice makes perfect unless of course you want to start a new trend of installing curb feelers in the front.
Old Jan 28, 2007 | 10:20 AM
Bakersfield's Avatar
Bakersfield
I always hope for a shinny car parked next to me on the driver's side, then I look for my reflection on the paint job. It is just like having a mirror, you can see exactly how close you are.
Old Jan 28, 2007 | 10:22 AM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
Takes a few times, but you'll get it down
Old Jan 28, 2007 | 11:01 AM
tsts's Avatar
tsts
Better 3 feet away than 3 inches too close!
