[Z06] C5Z vs C6Z weight difference?
Old Jan 27, 2007 | 08:48 PM
Vert_Fan's Avatar
Vert_Fan
Default C5Z vs C6Z weight difference?
I was under the impression that the new Z was considerably lighter than the previous Z. Is the following accurate?
According to corvettemuseum.com
02Z = 3118lbs curb weight @ 53Front/47Rear
06Z = 3130lbs curb weight @ ?Front/?Rear
Old Jan 27, 2007 | 09:09 PM
ptindall's Avatar
ptindall
I think that is right. Maybe you remember hearing that the new Z is lighter than the regular C6, which is true. 12lbs? That's pretty much the same.
Old Jan 27, 2007 | 09:41 PM
TwistedAphid's Avatar
TwistedAphid
Originally Posted by ptindall
I think that is right. Maybe you remember hearing that the new Z is lighter than the regular C6, which is true. 22lbs? That's pretty much the same.
It looks like a 12lb difference to me.
Old Jan 27, 2007 | 09:54 PM
Steve Theodore's Avatar
Steve Theodore
That is consistent with what I've read. However, I've seen lots of actual C5Z weights (with various fuel loads) but not comparable C6Z weights for reference. We all know that a C5Z with about 1/4 tank of fuel weighs between 3020 and 3040 pounds!
Remember that the C6Z has larger brakes, larger wheels/tires, and that extra glass in back to offset the lighter frame.
Old Jan 27, 2007 | 09:57 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
guess it depends on options....how much does NAV and Onstar add??
Old Jan 27, 2007 | 10:21 PM
z16kalel's Avatar
z16kalel
A Z16 carries even less weight
Old Jan 27, 2007 | 10:31 PM
Vert_Fan's Avatar
Vert_Fan
LOL...........
Wait, were you serious.........
If yes, I don't know.
Old Jan 27, 2007 | 10:35 PM
ptindall's Avatar
ptindall
Hmmm, that makes me look pretty stupid, huh? I think I'll just edit my original post. Then your post will look stupid!
Old Jan 27, 2007 | 11:28 PM
Thud's Avatar
Thud
If a C6Z owner wants to have the weight of a C5Z, the best idea is to go on a diet and lose 12lbs. (People seem to forget to add the weight of the driver)
Or convince the s/o to do so.
Old Jan 28, 2007 | 01:19 AM
froggy47's Avatar
froggy47
My 04 z16 is about 3050, but I would willingly add some weight for those brakes & 500 hp of the c6z.
Basically the c6z does weigh more because of the additional equipment/performance. Worth the extra lbs? I'd say so.
Old Jan 28, 2007 | 01:21 AM
TwistedAphid
touche
Old Jan 28, 2007 | 08:30 AM
Ryan L's Avatar
Ryan L
The only weight savings is the carbon fiber hood correct? I don't see it weighing much less than a stock C5 hood. Also, the polished Z16 wheels weigh a couple lbs more for each wheel. I think its a wash.
Old Jan 28, 2007 | 08:36 AM
drivinhard's Avatar
drivinhard
C5 SAE white papers say it's 17 lbs lighter.
Old Jan 28, 2007 | 08:41 AM
drivinhard's Avatar
drivinhard
No need. An aftermarket kit, like WW's SL6 13.06x1.25" kit is ~ 4 lbs lighter per side. Not sure about the weight of the stoptech kit, but any of the ones with 2 pc rotors are going to be lighter. In fact if I had a C6Z, 2 pc rotors (alum hat) would be the first on my list of upgrades.
With much fewer hi po street and race tires choices in the 18/19" C6Z sizes (many more available in 17/18 C5Z range) I'm not so sure I'd be quick to jump on 14" front dia rotors.
Old Jan 28, 2007 | 09:31 AM
AU N EGL's Avatar
AU N EGL
Always take the drivers wt into consideration.
Removing the 'dunlap*' affect helps the wt.
*the belly dun lap over the belt
Old Jan 28, 2007 | 09:34 AM
AU N EGL's Avatar
AU N EGL
Rotating wt or unsprong wt should be considared too. Lighter wheels and tires, going to 18" all around.
the front C6Z06 Rotor is 27 lbs. The front C5 rotor is 17 lbs So any advantage of the larger rotor is long lost in the added wt.
Bigger rotors does not always mean better braking. Keeping that rotating wt down, with a larger front tire foot print gives better braking
Old Jan 28, 2007 | 09:38 AM
Thud's Avatar
Thud
There's a spirited discussion in Off-Topic about this.... a wider front tire doesn't make the contact patch (footprint) larger, it just changes the shape.
To C5Z vs C6Z weight difference?
Old Jan 28, 2007 | 12:37 PM
AU N EGL's Avatar
AU N EGL
Come on over to the Autocross and Road race section. Reality sets in fast. Wider front tires do stop your car much faster then stock size.
I run a 305/30x18 up front.
Old Jan 28, 2007 | 02:29 PM
Vert_Fan's Avatar
Vert_Fan
So at 3233 lbs with me in the car, I officially have the lightest fully optioned Z?
How does that tire size affect the overall balance of the car?
Did you have to do away with the brake vents or even rub anywhere else?
Old Jan 28, 2007 | 02:46 PM
TransAmGT's Avatar
TransAmGT
I weighed my car last thursday night....this is full weight, nothing removed, with 1/2 tank of gas
Also has some 17" SS wheels with BFG DR's...probably a few lbs' heavier than the stock 18" Z06 wheels
here is what she came out to!
