Dead Battery Open trunk
Old Feb 3, 2007 | 08:37 AM
seatec's Avatar
seatec
Default Dead Battery Open trunk
Heyguys i am at a loss. I have 2000 C5 convertible. The battery is completely dead and i cant open anything that doesnt have a key or a latch. i need to get to my starter cables that are (you guessed it) in the trunk. how do i get the trunk open with no power at all? i casnt evenm get the front trunk open to put the top up.
Help
Old Feb 3, 2007 | 08:58 AM
bigjohn23's Avatar
bigjohn23
cable behind drivers seat, just pull it. on my 2004
Old Feb 3, 2007 | 09:12 AM
seatec's Avatar
seatec
the black cable that looks like a power cable? is it behind the carpet looking flap?
Old Feb 3, 2007 | 09:16 AM
seatec's Avatar
seatec
well there was ablack cable behind the drivers seat and i pulled it but now i two problems. it was a power cable of some sort. try to be a litte more specific as to where the "cable" is please
Old Feb 3, 2007 | 09:23 AM
coldwater-echelon's Avatar
coldwater-echelon
I'm not sure if unlocking the rear hatch in this manor involves any electronics but you can put the key in the drivers door an turn it 3 times and it will open the rear hatch.
Old Feb 3, 2007 | 09:30 AM
trymyz's Avatar
trymyz
I am not sure how this would work, but if you have jumper cable and another battery just hook ground up and and positive side to back side of alternator. I don't think I would start it, just give it power to open lid.
Old Feb 3, 2007 | 09:31 AM
MAC5's Avatar
MAC5
Release cable location could vary by model (coupe/conver) and model year.
My 98 owners manual shows the convert release cable located in the center rear storage area, coupe has two release cables for the left/right sides located in each of the side rear compartment storage areas.
Either way on a 98, you have to crawl into the rear compartment to find them.
Send someone small !
Just reread your original post and saw that your top is down, don't have a vert but suspect that your chances of getting to the rear compartment is limited.
seatec's Avatar
seatec
thats just it my jumper cable is locked in the trunk
Old Feb 3, 2007 | 09:33 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
WOW, if it's that dead, I'd charge it a bit first, even before trying to jumpstart it if you can... Your alternator wil be running at max trying to keep up... I don't know that this is really a problem but on these cars, with what stuff costs, I'd charge it at least for a couple or more hours first... If you have the time??
OR... Maybe after a few minutes of charging, there will be enough power to open the trunk? Maybe you don't have a battery charger??? If you own a Vette, yiou need one!! At least a tender.
Sorry about the cable...
Old Feb 3, 2007 | 09:38 AM
seatec's Avatar
seatec
maybe your right. i think ill go onto town and get a battery tender or something. to get me and the battery through the winter. now i have to figure out where that cable went that i dislodged. it has a connector spade on the end so i didnt really brake it. jst need to find out what it connected to.
is it jst me or is it stupid to not have a trunk release backup?
Old Feb 3, 2007 | 09:39 AM
TheWolverine's Avatar
TheWolverine
O.K. step away from the Vette! Go next door, or down the block, and borrow a set of cables, call AAA for a jump, call a friend tell them to buy a good set of cables, bring them over and help you get the car started, then give your friend (1) the money for YOUR new SPARE cables that stay in the garage, and (2) BEER for coming over to help you out, and (3) a big Corvette Wave to me for all this great free advice
Old Feb 3, 2007 | 09:40 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Keep in mind the Tender is a VERY slow charger and it will take a couple days to fully charge the VERY dead battery... You'll need something more if you want to get it going sooner than tomorrow.
If you live where it's winter, you need both chargers anyway!! Good luck!!
Old Feb 3, 2007 | 09:48 AM
TheWolverine
If you can, take the battery with you and have it checked. If it has a dead cell you will need a new one anyway.
Old Feb 3, 2007 | 09:52 AM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
Maybe you need to go buy a new battery. If your battery is completely dead as you state, you may or may not be able to charge it and you could have intermittant electrical problems associated with a low battery for months. New battery = money well spent.
Old Feb 3, 2007 | 10:53 AM
seatec's Avatar
seatec
just bought the die hard gold battery 2 years ago. hate to spend money on a new one
Old Feb 3, 2007 | 11:02 AM
Big-Red's Avatar
Big-Red
St. Jude Donor '06-'07-'08-'09-'10,'13-'14
If you bought it from Sears, take it back and get a new one pro-rated for the two years of use. I have Die Hard in my DD and swap it out about every three years, cost about 50 bucks..
Old Feb 3, 2007 | 11:13 AM
white top's Avatar
white top
This wont help you now but I had the same prolem 00 vert. What I did when I finally got into the trunk was tie a piece of cord to the wire manual trunk release and bring up behind the drivers seat. Called engineering what GM screwed up.
Jerry
To Dead Battery Open trunk
Old Feb 3, 2007 | 11:27 AM
dndrsn's Avatar
dndrsn
On a 2002 the cable for the tonneau cover is behind the waterfall.
The release for the trunk is on the back wall. Looks like you are supposed to leap out after opening the trunk.
Old Feb 3, 2007 | 03:05 PM
1stvette@60's Avatar
1stvette@60
St. Jude Donor '07
One of the best $39.00 I ever spent is for a battery jump start pack. This thing will jump start, be a 12v power supply, do away with jumper cables, is a compressor and a light.
You can throw it in the trunk if you have any doubts about your battery, also. Never have to worry about reverse polarity blowing an alternator or how you are going to get another car close enough to jump.
They have them everywhere, parts stores, Harbor Freight, Costco.
I dont think you would ever regret the money.
Old Feb 3, 2007 | 03:26 PM
convertible lover's Avatar
convertible lover
I Have a 2000 convertible and you are right on for the tonneau cover. But the trunk manual release is inside the center storage compartment. You have to take the cover off and feel along under the back wall to find it, but it is there. So it should work to open the tonneau cover and but the top up then you will have to climb in and open the center compartment to find it. But by then you already can reach the cables. good luck. Jack
