tires
Old Feb 8, 2007 | 06:33 PM
starroad99's Avatar
starroad99
Cruising
Default tires
I would like to know what tires are best for my car, Goodyear, michelin,kumo, ect. and for the best price. 1999 corvette. If any one can help me. Thanks
Old Feb 8, 2007 | 09:40 PM
Oldvetter's Avatar
Oldvetter
Runflats probably Michelins.
Non-Runflats, Goodyear GS-D3s.
Above are probably best tires, not best price.
Old Feb 8, 2007 | 10:09 PM
Dave68's Avatar
Dave68
...then check out the results from a Car & Driver comparison test. Although they used "only" a 325 BMW as a test mule, you are very likely to experience similar results with your C5. To minimize variables such as driving techniques, track surface temps, etc, C&D enlisted the help of the Tire Rack and their test mule vehicle. Although the track used was small, it's lined with sprinklers that can soak the asphalt. "It took three days to perform all the tests. We accerated to 50 mph and then braked to a standstill. There was a benefit to that lower speed: It ensured that we were measuring the braking performance of the tires and not just brake fade."
"In addition to factoring the wet and dry scores, we gave points based on a tires's price and tread-wear grade, which is a rough estimate of how long a tire will have usable tread." "Our test focused on measuring performance, so we decided that results in the dry-lateral grip, for example - would carry the most weight."
So, without further adeau, here're the results:
(Best to worst):
NUMBER 1: Goodyear GSD3: "As an all-around performance tire, you can't beat this Goodyear. It was the best performer in all three wet-track tests and was very competent in the dry. It generated .94g on the dry skidpad, only .01g off the first place (dry) BFGoodrich and tied with the Yokohama and Hankook.
The Goodyear gripped so well, that you might not have been certain that the road was wet. It held onto the wet track with .82g of stick, an impressive figure considering the worst tire in that test made only .67g.
...And like the Continental, the Goodyear had a high 280 trad-wear grade. At $145, ieach, it's $34 cheaper than the most expensive (guess which tires have THAT distinction!).
2nd place: Continental ContiSportContact 2: "It simply didn't feel as sporty as the others.....on dry surfaces, the Conti never rose above third from last among 11 tires. It felt soft and imprecise. But in the wet, the spread from best to worse was 15 percent, which made for a larger point spread (giving the Contis a boost). Plus the Continental had a 280tread-wear grade that was the highest (tied) for this test.
3rd place: Yokohama Advan Neova AD07: Excellent dry performance, but a bit on the slippery end in the wet stuff - expensive at $175 apiece.
4th place: Michelin Pilot Sport PS2: "At $179, the PS2 is the most expensive tire in the test." Competent, but expensive sums up this tire.
5th place: Hankook Ventus R-S2 Z212: At $99 each, these are the least expensive tires - very good on dry pavement, but "greasy and slow to recover" on the wet stuff.
6th place: Dunlop SP Sport Max: "In the dry, the tire seemed to lose its confidence..."
7th place: Pirelli P Zero Rosso Asimmetrico:"In the dry-lateral-grip test, the Pirelli tied for second to last, and it finished seventh in the dry-braking test.
8th place: Toyo Proxes T1R: "...the Proxes never placed higher than eighth in any test"...nuff said!
9th place: Bridgestone Potenza RE050A: "it felt dull and disconnected and was somewhat soft and imprecise when driven hard."
10th place: BFGoodrich g-Force T/A KD: Outstanding performance on dry surfaces, but very scary on wet surfaces - don't get caught in a rainstorm wearing these shoes...
11th place: Kumho Ecsta MX: "They didn't offer much grip and the time of 30.28 seconds in the dry autocross was .62 second slower than the fastest tire. That may not seem like much, but our course was only 0.3 mille long, and on a longer track, that gap would be commensurately greater." "And although the MX - at $136 per - was the third-least-expensive tire in our test, the high score in the price category wasn't enough to regain ground lost in the performance tests."
On a congratulatory note, the first place tire is made right here in the USA by an American tire company
Old Feb 8, 2007 | 10:42 PM
waupachino's Avatar
waupachino
With your Question you are going to get a lot of subjective opinions. I do not believe there is one definite answer to the best. I will give my opinion, I believe the Michelin PS2's to be one of the best performance tires. They are also one of the highest priced tires also and that is probably why they came in 4th in the above report. I would not say they are the best all season choice for your car. I believe they are not recommended for use in freezing temperatures. For all season use I would recommend the Michelin Pilot Sport A/S. I have run Michelin on several cars now and have had nothing but good luck with them.
Old Feb 9, 2007 | 12:37 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
I work with tires every day(no, not my own! ), and we see less problems with michelins than we do with any other tire brand, and I HATE the FRENCH, but I do LOVE their fries!
IOW...Go with Michelins, less trouble down the road(15K miles) and less hassles for you
Old Feb 9, 2007 | 01:57 AM
RIJVETTES's Avatar
RIJVETTES
I got the BFG G force. They do grip like hell and show no wear at 15Kmiles. I dont agree that they dont perform on wet roads. I feel VERY secure in the rain.... but that rarely happens in San Diego. Global warming... buts that a different story.
Old Feb 9, 2007 | 01:35 PM
For non-runflats - I'd recommend the Goodyear GS-D3s or the Firestone Wide Ovals.
For runflats - either the Michelin or the Firestone Firehawks.
Old Feb 9, 2007 | 03:48 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
This might help you out. Go to Tirerack.com. Compare different tires and see what other people have to say about the tires they bought.
To tires
