Rear Side Markers??
Old Feb 11, 2007 | 04:55 PM
casisthefirst's Avatar
casisthefirst
Default Rear Side Markers??
does anyone know how to remove the rear side markers?
Ive been trying to replace the bulbs with LED's, but Im having trouble figuring out how to take the little red lamp out of the side...I noticed in the trunk, on the side by the lamp, there is a removabable plastic **** but after that, I dont know...
can anyone help?
Old Feb 11, 2007 | 05:03 PM
keith954's Avatar
keith954
St. Jude Donor '06, '13
remove the tail light closest to the marker you are working on... then you'll be able to see the backside of the marker... there are 2 12mm nuts on each side of the marker
Old Feb 11, 2007 | 05:17 PM
casisthefirst
go it, thanks for the quick response!
Old Feb 11, 2007 | 05:19 PM
oldschoolvette's Avatar
oldschoolvette
if its a vert you may want to remove the antena its two bolts and aloows you to see
Old Feb 11, 2007 | 06:37 PM
Patches's Avatar
Patches
Old Feb 11, 2007 | 07:24 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Don't know if there is a difference between the years or body style but my 2001 coupe had 11mm nuts.
Old Feb 11, 2007 | 07:26 PM
casisthefirst
no, its a coupe...
so what is that plastic **** on the side of the inside trunk for?
Old Feb 11, 2007 | 09:00 PM
Take out the outside rear taillight and go in through there or take out the fender liner and go through there.
Old Feb 11, 2007 | 09:25 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Originally Posted by casisthefirst
no, its a coupe...
If it's a black **** it holds the panel inside interior panel in place. Also they are used for cargo nets.
To Rear Side Markers??
