battery question
Old Feb 18, 2007 | 07:54 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
Default battery question
My 04 is 3 years old , 34k on the clock and it still has the original battery. I am thinking I should go ahead and replace it know that it cant last much longer , should I ? And of course thinking of the red top??????I have not had a lick of problem from it but I dint want to either and I have a long trip coming up in about 10 weeks.
Old Feb 18, 2007 | 07:58 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Yep, it's time for a new one.
Optima Red Top's are good options - there are others. Depends on your preference.
Old Feb 18, 2007 | 08:40 AM
Oldvetter's Avatar
Oldvetter
Your 2004 is be a top post battery. If it is, you can get a much cheaper battery, like a Sears Diehard. The reason most people get a "Gel" or "Glass Mat" battery is due to leaking on the computer, BUT this leaking is only with side terminal batteries.
Short history, GM went to a Glass Mat battery to solve leaking on computer, but they had battery reliability problems, so they went to a top post battery.
BTW, overtorquing sidepost battery terminals can cause leaks. Use only 11 ft-lbs.
Old Feb 18, 2007 | 08:50 AM
mojo1's Avatar
mojo1
Originally Posted by Oldvetter
I think your 2003 may be a top post battery. If it is, you can get a much cheaper battery, like a Sears Diehard. The reason most people get a "Gel" or "Glass Mat" battery is due to leaking on the computer, BUT this leaking is only with side terminal batteries.
its a 2004 and yes it is top post, good point about the side post being the ones with the leaking problems.hell, I use the wallyworld elchepo Everstart im my older cars and have had god luck with them but I theink the vette deserves better...
Old Feb 18, 2007 | 09:15 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
WHY??? Buy anything other than an Optima. They are over priced pieces of sh*t that have a loooong history of premature cell failure.
Old Feb 18, 2007 | 10:21 AM
jrose7004's Avatar
jrose7004
I've had my Red Top for 2 years and haven't had a problem.
Old Feb 18, 2007 | 10:24 AM
Yes, some of the Optimas lately have had problems as reported here on the forum. But, mine has been in the car for 5.5 years and still going strong. So not all of them are pieces of junk.
Old Feb 18, 2007 | 10:27 AM
DBL001's Avatar
DBL001
I've been hearing bad things about the Optima lately too. Do a search on this forum to find out more.
Old Feb 18, 2007 | 11:08 AM
C5-Dawg's Avatar
C5-Dawg
I have a new AC Delco 6 yr battery in mine. I just prefer the stock appearance of the battery over the Optima and other aftermarket ones.
Just curious, why would you replace a battery afer only 3 yrs and 34K miles when it shows no signs of dying??
Old Feb 18, 2007 | 12:36 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
> 3yrs here with no problems ... sits for extended periods of time and has never failed me.
Old Feb 18, 2007 | 02:52 PM
mojo1's Avatar
mojo1
Cheap insurance , most of the aAC delco's I have had were lucky to make it past 2 years.
Old Feb 18, 2007 | 03:08 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
I dont understand why so many people change there batteries so early. My 01 vette sometimes sits for 2 weeks between drives and it sits all winter. All i do is unhook the battery for winter hook it up and fire her up, never once a problem. My 97 cavalier has the origional delco battey my kid has the car at school, sits for 2 weeks sometimes in Chicago winter fires right up for him. 94 Camaro had origional battery until we changed it in 2002. I think many people change there batteries for no reason, IMO when my car sits for a week or so and the battery is dead Ill replace it. My boat is a 97 and this year the battery finally crapped out and its probally because we have a big stereo in it and the amps run the battery down alot while the boat isnt running
2KFRC5's Avatar
2KFRC5
I realize my battery was different from yours, but, my original side-post ACDelco lasted a full 6yrs before the 1st sign of weakness. That's when I replaced it. I replaced it with a DieHard Gold. 36mo free replacement, 100mo pro-rated. Whatever your decision, good luck.
Old Feb 18, 2007 | 03:22 PM
zTrek's Avatar
zTrek
I can't speak for other areas, but AZ is hard on batteries. I change the batteries in all my vehicles (including a motorcycle) on after a predetermined length of time. There is no greater inconvenience than coming out to your car if you are out and about and it won't start. Here in AZ, batteries fail with zero warning. This could be a big problem depending on where you are and what time it might be. Like another poster said, changing batteries out on a predetermined basis is cheap insurance indeed.
Old Feb 18, 2007 | 03:54 PM
DeeGee's Avatar
DeeGee
Take a look at this poll before you decide on a replacement.
Red Tops have their share of failures but no worse than others. AC Delcos don't look good based on this and the older ones were prone to leaks.
http://forums.corvetteforum.com/show....php?t=1469503
pentavolvo's Avatar
pentavolvo
I guess so im just a big fan of waiting till they die. I figure chicago winters cant be easy on a battery either. I think the biggest problem with batteries in vettes is many of us dont DD them so the cars sometimes sit for 2 weeks so if your battery is half way on its way out already it doesnt help when the car sits for 2 weeks
On a random note, tell me this isnt crazy. A buddy of mine had been looking for a beater and there was an old nissan sitting in this ladies driveway that hadnt moved in years the fender was all smashed in he went and talked to her she said 20 bucks and its his title and all. Had been about 4 years since the car moved put the key in the ignition it cranked slow but fired right up car was sitting 4 years battery still started the car 2 years later it still starts the car and its with him at school and sits outside for weekes sometimes
Old Feb 18, 2007 | 07:26 PM
ALLEGRO's Avatar
ALLEGRO
Four years and a month, 22k on the clock and the OEM gel side-post with no problems at all. Having bought a zillion batteries for cars, trucks. motorcycles, lawn tractors and motorhomes, I will return to Wally World and do business again.
To battery question
Old Feb 18, 2007 | 09:07 PM
Dave68's Avatar
Dave68
My OEM AC Delco battery is still performing perfectly after more than 5.5 years. Save your money for other things, your battery probably has another 3 years of life left. AC Delco has significantly improved their battery cases, leaking is a thing of the past. When My battery finally dies, I'm going with an AC Delco Professional - 50 month free replacement warranty - best in the industry.
Old Feb 18, 2007 | 09:57 PM
silverbullit99's Avatar
silverbullit99
I had one ,,, it's junk .. unless it's a daily driver it might give you headaches. The RedTop does not seem to hold the charge..
Old Feb 19, 2007 | 07:14 AM
mojo1's Avatar
mojo1
Man after seeing some AC Delco s lasting so long , I might just let it ride.I have not had any problems yet !
