Battery Minder hookup
Old Feb 19, 2007 | 12:31 PM
buckcessna's Avatar
buckcessna
5th Gear
Default Battery Minder hookup
This is my first winter with my 04 C5. As the weather here in MA is nasty, I'm storing her for the next few months. Following some suggestions from the forum I bought a battey minder. I have the original AC Delco battery and hope I can get some help on hooking the tender up. 1. Is the ground on the AC Delco battery attached to the postive or negative post? 2. the instructions say to attach the 2ed minder lead clamp to the block, but the lead won't reach, any other suggested points to attach the second lead? Any advice would be really appreciated. Thanks in advance.
Old Feb 19, 2007 | 12:34 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
uh... ground would be negative
just connect em right at the battery
Old Feb 19, 2007 | 05:42 PM
Novat_99's Avatar
Novat_99
I also have an '04 and connect right to the battery top posts
Old Feb 19, 2007 | 08:49 PM
steck's Avatar
steck
the battery in the C5 is a negative grounded battery.
my instruction manual for my 'battery float charger and maintainer" says :
connect the positive cable to the positive terminal on the battery.
BUT, connect the negative cable to the chassis somewhere.
thats just mine tho....
Old Feb 19, 2007 | 09:51 PM
oaks99's Avatar
oaks99
black to black , red to red
Old Feb 20, 2007 | 01:24 AM
Old Feb 20, 2007 | 01:31 AM
DeeGee's Avatar
DeeGee
I had a really old MG once that had positive Earth. I don't think there are any of them out there any more are there?
Negative earth, ground is the black.
I hook my tender up at the battery.
Old Feb 20, 2007 | 09:49 AM
vetdude's Avatar
vetdude
On the Z06, from the Battery Tender Plus - postive to positive on aux. fuse block in engine bay; negative to engine block.
Old Feb 20, 2007 | 09:57 AM
87SAM's Avatar
87SAM
Hooking the negative to block or frame the final connection – A manufactures way of protecting their butt in case sparks erupt and the battery blows itself on you. Not so much anymore with today’s batteries.
Old Feb 20, 2007 | 10:40 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Positive first, Negative last when hooking up...Reverse the order when taking off.
z06Bigbird's Avatar
z06Bigbird
I think it was George Washington who drove the last car with a positive ground.
Ed
Old Feb 20, 2007 | 11:07 AM
rickko's Avatar
rickko
Ed
It must have been a gift from the British...
Old Feb 20, 2007 | 01:50 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Called the battery tender company because their instruction book did not make sense to me and they told me just hook it up black to black and red to red.
Old Feb 20, 2007 | 01:54 PM
steck's Avatar
steck
thanks for that input....i was wondering why i had to hook it up that way !!
Old Feb 20, 2007 | 03:22 PM
DeeGee's Avatar
DeeGee
Yup
Old Feb 20, 2007 | 10:36 PM
rustyguns's Avatar
rustyguns
Ed
No! It was the British! Goofy Limey's! wrong ground! wrong side of the road! lol
To Battery Minder hookup
