That tire would need at least a 12" wide wheel and mini tubs. The largest tire and wheel set up would be 18x9.5 wheels with a 265/35/18 for the front. And a 19x11 with a 305/30/19 for the rear. The front wheels need to be 54-59mm offset and the rear wheels need to be a 62-65mm offset. This will fit the car with out any fitment issues and the tires won't stick out.
Russ Kemp
You can fit it on a smaller rim, but then you get a lot of problems, do a search, this question is asked 2 times a week.
