having problems aligning my BB bullets
Old Mar 3, 2007 | 11:36 PM
2klude's Avatar
2klude
Default having problems aligning my BB bullets
I installed my bb bullets 6 months ago and they aligned perfect for the 1st month. since then the left side hands down lower about 1inch. I can pull the exhaust up by hand and it goes back into alignment but after i drive the car a few times it drops back down.
I checked and tighted everything and nothing seems to work.
any tips or ideas?
Old Mar 3, 2007 | 11:41 PM
oaks99's Avatar
oaks99
if they are going down something has to be loose , and my guess is it is loose where your b&b goes into cat back pipes the flange just in front of rear wheels .
oak
Old Mar 4, 2007 | 02:09 AM
scformula's Avatar
scformula
Check your exhaust hangers, I had one break on me and I had the same problem. Easy fix for an exhaust shop, I think they charged me $5 to get it back on.
Old Mar 4, 2007 | 07:52 AM
trussme's Avatar
trussme
Default Fixed Mine...this way:
any tips or ideas?
Yes, I had the same problem with my B&B PRT's...it didn't matter how tight we got the clamps, they would still slip & change position after driving...we realigned them correctly, and spot-welded them & bingo! they stay perfectly aligned ...cause they can't shift now..
Old Mar 4, 2007 | 08:03 AM
97Rob's Avatar
97Rob
Hanger is probably bent just enough to cause it to slide out of the grommet. I'd push it down favoring the cat back.
Old Mar 4, 2007 | 08:16 AM
c5_alive's Avatar
c5_alive
St. Jude Donor '08
That would be the best bet. I don't think it would be the flanges in front of axle because thats not where the swing joint is at, it's the band clamp thats not "squishing" the two pieces together enough.
Old Mar 4, 2007 | 08:25 AM
wolfman04's Avatar
wolfman04
Had that done when they installed mine.
Old Mar 4, 2007 | 09:02 AM
97Rob's Avatar
97Rob
I wouldn't want to weld cat backs to my car. Especially those being so loud. Had B&B on my car and the drown was CRAZY. Theres a reason they are not hanging properly, I'd want to fix it.
Old Mar 4, 2007 | 09:10 AM
c5_alive's Avatar
c5_alive
St. Jude Donor '08
really all you need is a few good tacs, would still be easy to remove.
Old Mar 4, 2007 | 09:14 AM
vettes4fun's Avatar
vettes4fun
I had to put a small weld on mine. Where the two pipes go together I could not get the clamps to tighten down good so I put a small weld up at the top where it could not be seen, worked great.
02gt350's Avatar
02gt350
its the clamp on the tip pipe. Put as much *** into it as you can. Mine never fall.
To having problems aligning my BB bullets
