[Z06] Ok..Rattle on engine shut down
Old Mar 4, 2007 | 10:31 PM
BitViper's Avatar
BitViper
Default Ok..Rattle on engine shut down
Ok..its starting to wear on me..when ever I turn my engine off I get this rattle from the engine compartment
Im just checking to see if this is normal for the Z06..Im thinking its not..but..with noisy transmissions and rear ends being normal just thought Id check....
Ive got 14 days left on my bumper to bumper GM warranty...
Old Mar 4, 2007 | 10:32 PM
1slo6's Avatar
1slo6
rattle like a tin can rattle or rattle like clak clak.....if it sounds like a tin can mine does the same....
Old Mar 4, 2007 | 10:34 PM
BitViper's Avatar
BitViper
No a tin can....Ok I feel better now!
Old Mar 4, 2007 | 10:37 PM
Brois24's Avatar
Brois24
yup, its normal. Mine does it too. Nottin to worry about!!
Old Mar 4, 2007 | 10:38 PM
jtkeller's Avatar
jtkeller
St. Jude Donor '07
push the clutch in when turning the car off
Old Mar 4, 2007 | 10:42 PM
DigD@ddy's Avatar
DigD@ddy
Not sure if these cars have dual mass flywheels like the C4 or Audi S4's or not, but thats usually the case wheb they start to go bad...just my .02
Old Mar 4, 2007 | 11:21 PM
rico750sxi's Avatar
rico750sxi
MIne does it too, would love to know what it is. I thought it was my exhaust or something.
Old Mar 4, 2007 | 11:37 PM
Brois24's Avatar
Brois24
I will try it!!!
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
Its the throw out bearing.
Push in the clutch when you shut her down.
Its normal
Old Mar 4, 2007 | 11:42 PM
76REDVETTE's Avatar
76REDVETTE
I get the same noise sometimes. I thought it was my IRL timing chain. Oh well, no biggie.
Old Mar 5, 2007 | 12:12 AM
1slo6's Avatar
1slo6
pushing in the clutch on shut down worked for me too....
Old Mar 5, 2007 | 01:36 AM
tvlance's Avatar
tvlance
whoa now i can finally post on things as a USER and OWNER of the car. woo hoo!! first thing i noticed with my EB '02 with 32K miles is a rattle coming from the tranny when the engine is at idle and clutch is engaged. it sounds so cheesy when i turn the engine off. and yes i noticed that if i hold the clutch in OR push the shifter against any gear (with clutch engaged), i dont get the rattle nearly as much. oh well, as long as it's normal and nothing i need to freak about.
.... now if i can just figure out why both my cig lighter plugs aren't getting any power. fuses are good on both, yet neither work. its goin to the chevy dealer tomorrow.
Old Mar 5, 2007 | 08:23 AM
AU N EGL's Avatar
AU N EGL
you are turing the car off with the clutch out? Did you drive an automatic before?
Pull up to the place your going to stop, push clutch in and let the car ideal for a 10-15 sec. then turn the key off.
Old Mar 5, 2007 | 10:12 AM
mr-z's Avatar
mr-z
Its normal.
Old Mar 5, 2007 | 10:35 AM
Road machine's Avatar
Road machine
Many previous threads on this. As per your owners manual... car must be in reverse when shutting down. If the car is in reverse when you shut it down, then you must have the clutch pushed in. If you follow this procedure you will not get the rattle. Reverse is the best gear to have the car in to keep it from rolling when you are not in the car.
Old Mar 5, 2007 | 10:38 AM
USAF POL's Avatar
USAF POL
This is true. Page 99 (I think) in the owners manual
Old Mar 5, 2007 | 11:15 AM
BitViper's Avatar
BitViper
Really...
Well I guess its time to
RTFM....
reverse..go figure.
I never leave my car in gear...anyone seem the film of the guy letting his son/friend drive his brand new Shelby 500? Started it right up an drove thru the back wall of the garage
To Ok..Rattle on engine shut down
Old Mar 5, 2007 | 11:30 AM
DrumStix's Avatar
DrumStix
Originally Posted by BitViper
Really...
RTFM....
reverse..go figure.
Saw it. His kid did not RTF driving M.
Old Mar 5, 2007 | 05:38 PM
Road machine
Really...
RTFM....
reverse..go figure.
Very Hard to do as no car today will start without you stepping on the brake. Your brake will over power your drive wheels, thats why you can step on the brakes and do a burn out (in other words you would do a burn out but not go flying through the back of the garage). I also doubt that if he didn't push the clutch in the car would have started. He must have thought he was in a forward gear but instead went backwards.
As for not leaving the car in gear... there are a few posts on this sight about the E brake not holding and guys finding thier car out of the parking space they left it in or worse rolling out into the street and hitting things. The e brakes on these cars do leave a bit to be desired.
Old Mar 5, 2007 | 05:44 PM
lawZ's Avatar
lawZ
Call Dennis Fichtner and renew that warranty!
