swapping engines
Mar 13, 2007 | 01:09 AM
swapping engines
Is it possible to put a crate z06 engine in my 2000 vert. if it is possible what other items would i have to buy?
Mar 13, 2007 | 02:31 AM
Quote:
Originally Posted by
choppergil
Yes it is, I believe the computer and such are the same.
Mar 13, 2007 | 05:09 AM
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Are you asking about a C5, or a C6 Z06 crate engine?
By "crate" we'll assume it is a long block (including intake).
A C5 will 'fit' - no problems. You will need a tune.
If it is a C6 - be aware that there are numerous issues to overcome (placement of the oil sump, computers change out, etc.).
Mar 13, 2007 | 09:04 AM
I just met a guy this weekend with an LS7 in his 98.
Mar 13, 2007 | 10:06 AM
St. Jude Donor '12
choppergil
If you are just doing it for the extra hp, don't bother. Get a head cam package installed on the existing car. (Yes the LS6 will fit with no issues-- LS2/7 will require other items)
Chris
Mar 13, 2007 | 11:26 AM
brandtdavis
Bet that wakes the car up.
Mar 14, 2007 | 03:25 PM
JDs00PewterCoupe
Just a "little bit". I have a video that I will upload this week sometime.
Mar 14, 2007 | 03:32 PM
choppergil
if you have to replace the engine for other reasons, good idea. If you've got a good engine, you're better off just doing a head/cam swap because that's pretty much all the LS6 is.
Mar 14, 2007 | 07:24 PM
St. Jude Donor '12-'13-'14
does anyone have a step by step write up on how to pull a C5 motor from the top to drop in a new one ?
Mar 15, 2007 | 12:17 AM
here you go ....http://www.cajundude.com/c5techhome.htm
lots of good stuff here
Mar 15, 2007 | 09:10 AM
More reason to pay someone to do it
