Kumho Tires?
Old Mar 19, 2007 | 09:36 AM
Watchful's Avatar
Watchful
From: An Englishman drinking his way through Tewksbury MA
St. Jude Donor '09
Originally Posted by itza56
If you switch away from the run flats, do you lose function of the tire air pressure function ?
also, if going to non run flats, and you pop a tire 100 miles from home, do you just sit on the side of the road ?
TPS still works fine with non-run-flats.
If you get a flat with non-run-flats, you have options. You can sit on the side of the road, keep driving on it, make a call, or try a roadside repair. I carry a can of fix-a-flat, a puncture repair kit and a compressor in the back of the car for that purpose. The fix-a-flat might stuff your pressure sensor if used, but those things are only $100 each.
Old Mar 19, 2007 | 09:49 AM
Dave68's Avatar
Dave68
Originally Posted by CORSAIR II
Why not buy the tires that fit the driver (Kumhos - very good, affordable tire) and take the extra money - buy your wife a new dress - take the kids out for pizza - and enjoy life!
By the same token, why not buy Pep Boys brake pads, Gabriel shocks, Kmart wax, and ebay steel wheels? C'mon, we're talking about a car that costs $50,000 new. Let's not treat it as if it is a Kia that cost $8,000 new.
Old Mar 19, 2007 | 11:24 AM
BillY2KFRC's Avatar
BillY2KFRC
I had Kumhos on my old Vette and was not happy with them. They offered acceptable levels of grip. They worked OK at the auto-x and gave me 1.9 60fts at the drag strip.
But on the street they killed the car for me. The steering feel was very vague. Front end just felt very mushy on turn-in. The car also felt floaty and less secure at highway speeds and above. My alignment was dead on and I played with tire pressures quite a bit. I could never get a setup I liked with these tires. These were stock Z06 sizes (except for 275 in front) on Z06 OEM rims.
I switched to more expensive PS2s and wish I spent the extra money in the first place. I also found the OEM Goodyear Supercars to be much better than the Kumhos as well.
Old Mar 19, 2007 | 11:51 AM
crimsonc5's Avatar
crimsonc5
I ordered a pair for the rear today. I drive my car daily, I am sure they will be fine. They are not the cheapest tire for our car, and the ratings from discount tire are pretty good. We shall see.
Old Mar 19, 2007 | 12:30 PM
TAGVETTE's Avatar
TAGVETTE
I've had ASX's on mine for a while. The grip is not as great as I'd like, but they aren't supposed to be. I was using it as a DD for a while. The next time around, I'll either get Michelin Pilots's or Kumho's. I don't like the road noise of the EMT's. Sounds like a tank.
Being non-runflats, they do handle a little differently.
Old Mar 19, 2007 | 07:49 PM
Watchful's Avatar
Watchful
St. Jude Donor '09
Pick any tire and you can likely find someone delighted with it, and someone disgusted with it...
Well, except these beauties maybe:
http://www.tirerack.com/tires/tires....ECSTA+DX+Aroma
http://www.tirerack.com/tires/tires....+Colored+Smoke
First time I've seen these, don't all rush out and buy them at once.
Old Mar 19, 2007 | 08:40 PM
stampede3's Avatar
stampede3
Originally Posted by Dave68
You essentially get what you pay for when it comes to tires.....read on!
Although Car & Driver used "only" a 325 BMW as a test mule, you are very likely to experience similar results with your C5. To minimize variables such as driving techniques, track surface temps, etc, C&D enlisted the help of the Tire Rack and their test mule vehicle. Although the track used was small, it's lined with sprinklers that can soak the asphalt. "It took three days to perform all the tests. We accerated to 50 mph and then braked to a standstill. There was a benefit to that lower speed: It ensured that we were measuring the braking performance of the tires and not just brake fade."
"In addition to factoring the wet and dry scores, we gave points based on a tires's price and tread-wear grade, which is a rough estimate of how long a tire will have usable tread." "Our test focused on measuring performance, so we decided that results in the dry-lateral grip, for example - would carry the most weight."
So, without further adeau, here're the results:
(Best to worst):
NUMBER 1: Goodyear GSD3: "As an all-around performance tire, you can't beat this Goodyear. It was the best performer in all three wet-track tests and was very competent in the dry. It generated .94g on the dry skidpad, only .01g off the first place (dry) BFGoodrich and tied with the Yokohama and Hankook.
The Goodyear gripped so well, that you might not have been certain that the road was wet. It held onto the wet track with .82g of stick, an impressive figure considering the worst tire in that test made only .67g.
...And like the Continental, the Goodyear had a high 280 trad-wear grade. At $145, ieach, it's $34 cheaper than the most expensive (guess which tires have THAT distinction!).
2nd place: Continental ContiSportContact 2: "It simply didn't feel as sporty as the others.....on dry surfaces, the Conti never rose above third from last among 11 tires. It felt soft and imprecise. But in the wet, the spread from best to worse was 15 percent, which made for a larger point spread (giving the Contis a boost). Plus the Continental had a 280tread-wear grade that was the highest (tied) for this test.
3rd place: Yokohama Advan Neova AD07: Excellent dry performance, but a bit on the slippery end in the wet stuff - expensive at $175 apiece.
4th place: Michelin Pilot Sport PS2: "At $179, the PS2 is the most expensive tire in the test." Competent, but expensive sums up this tire.
5th place: Hankook Ventus R-S2 Z212: At $99 each, these are the least expensive tires - very good on dry pavement, but "greasy and slow to recover" on the wet stuff.
6th place: Dunlop SP Sport Max: "In the dry, the tire seemed to lose its confidence..."
7th place: Pirelli P Zero Rosso Asimmetrico:"In the dry-lateral-grip test, the Pirelli tied for second to last, and it finished seventh in the dry-braking test.
8th place: Toyo Proxes T1R: "...the Proxes never placed higher than eighth in any test"...nuff said!
9th place: Bridgestone Potenza RE050A: "it felt dull and disconnected and was somewhat soft and imprecise when driven hard."
10th place: BFGoodrich g-Force T/A KD: Outstanding performance on dry surfaces, but very scary on wet surfaces - don't get caught in a rainstorm wearing these shoes...
11th place: Kumho Ecsta MX: "They didn't offer much grip and the time of 30.28 seconds in the dry autocross was .62 second slower than the fastest tire. That may not seem like much, but our course was only 0.3 mille long, and on a longer track, that gap would be commensurately greater." "And although the MX - at $136 per - was the third-least-expensive tire in our test, the high score in the price category wasn't enough to regain ground lost in the performance tests."
On a congratulatory note, the first place tire is made right here in the USA by an American tire company
I read that whole thing, even they admitted it was real close.
And IMO tires are one of the only things where "You get what you pay for" doesn't matter.
But hey what do I know, in the years of the family owned tire store you know what 2 brands I saw more shifted belts in?
Goodyear and Michelin.
Why are they so expensive? Well it was said before.
Advertising and labor cost.
Kuhmo makes a great tire. I've run the MXs many many times on the road course with just as good or better lap times than the BFGs or the Goodyears I had before.
Old Mar 19, 2007 | 09:09 PM
gpracer1's Avatar
gpracer1
On friday I got new Z06 wheels and Z06 sized Kumho mx's (front 275/40). The ride is much softer, no bumpsteer, and traction is much better than the runflats.
BUT, they feel like sponges, turn in is soft and on sharp cornering they feel like they are gonna fold under the rims
That part pisses me off. I like to run my car hard and it does not inspire any kind of confidence. I think I should have gone with 35 and 30 series instead. The tires seem kinda tall too. Im running 31 psi front and back, cold.
PS, treadwear is 220 and the sidewall flex feels like 5 times more than the runflats.
Old Mar 19, 2007 | 09:30 PM
BRKLYN's Avatar
BRKLYN
Originally Posted by Barrier
I went with the Kumho SPTs. I think they are Fine.
I don't race at a track. I don't drive in really bad weather if I can help it. My tires will most probably age out before they wear out. I don't need to see TV or Mag advertisements proclaiming how great they are.
I do like how quiet they are compared to the GY RFs. I do like how well they grip. I do like the Money I saved. I do like the way Kumhos worked on my last Corvette.
Barrier
the key word quiet and affordable.I'll give em a try when it's time. tire rack under $500.00, plus 43 shipping
Old Mar 19, 2007 | 09:39 PM
F16 1UB's Avatar
F16 1UB
Just ordered from Tire Rack Khumo Run Flats. $866 shipped. Getting them installed 3/22. Will let you know. I won't miss my GY. I also am not at agressive driver. Got 31,000 on GY.
Old Mar 19, 2007 | 09:50 PM
uk_vette's Avatar
uk_vette
In my opinion, Kumho do a good tire at a great price.
Like been said before, for daily drivers, these tires are excellent.
Sure, if you want to do racing in the rain / damp, well. . . . .
So, where every buck counts, it is kumho's for me.
They all wear away eventually any how,
Oh, and good mileage also.
Old Mar 19, 2007 | 11:19 PM
hotrod03's Avatar
hotrod03
I will post my results Tues. Having the Kumhos mounted
Old Mar 19, 2007 | 11:44 PM
  #33
Dave68's Avatar
Dave68
I called the Tirerack on three different occasions over the years (keep in mind that they do their own tire-testing and know first hand how well the tires they sell, perform.) and each time I asked how the Goodyear GSD3s compared to the Khumos, I was told, "The Goodyears are definitely superior."
It doesn't take a rocket scientist to realize that there must be some truth to that statement, having been told more than once by different Tirerack reps, but as more than a couple of people have stated here, these are not in the same league as the D3s and PS2s. As long as you realize that when you buy, you may not be dissappointed.
BTW, here is an early tire test that compared the GSD3s to some of the better tires (at the time):
"Productreview: F1 GS D3
By Dan Barnes
Photography: Dan Barnes
Designed in Europe, the Eagle F1 GS D3 is Goodyear's "first truly global product," and its first tire aimed at the maximum-performance tire segment. The Eagle F1 GS D3 targets sport compact and tuner vehicles, and follows Goodyear's traditional emphases of maximum wet performance and good, all-around driveability. Goodyear is producing the Eagle F1 GS D3 in 39 sizes, from 15 to 21 inches.
The Eagle F1 GS D3 has internal construction features expected from the latest maximum-performance tire, including high-tensile steel belts, spiral-wound cap plies for excellent roundness and high-speed durability, high ply turn-up for strong sidewalls and quick response, and a rim flange protector molded into the sidewall.
It's the tread design that sets the new Eagle apart. It's divided into three zones; a solid center rib for good steering response is connected to shoulders with large, solid tread blocks by a series of power transfer bridges. The latter are part of what Goodyear calls V-TRED. The diagonal grooves are three times the length of the contact patch, helping evacuate water and avoid trapping air, thus reducing noise. Goodyear refers to the tread compound by the AAtrax moniker, emphasizing the tire's AA UTQG traction rating.
We sampled the Eagle F1 GS D3 at Goodyear's proving grounds outside San Angelo, Texas. The 7,250-acre facility has 58 miles of roadway with 53 different surfaces. There we witnessed demonstrations of wet-traction testing with a pickup truck and trailer test rig, as well as the phosphorescent hydroplaning test made famous in Aquatred commercials. The latter can be done at speeds approaching 200 mph for racing applications. We also drove the new Eagle F1 on a dry-handling loop in 2002 Audi A4 sedans. At moderate to high slip angles, the Eagle F1 felt like a good, ultra-high-performance tire, but it does make more noise than most tires in the maximum-performance category when cornering loads rise. The grip-slip knee in the load/slip-angle curve was very gradual. That made the tire extremely forgiving, but it also made it difficult to decide how hard the tire wanted to be pushed for best speed. Overall, though, the strongest impression was that the Eagle F1's capabilities were well beyond those of the stock Audi's suspension, and a complete evaluation would require a car with more aggressively tuned dynamics.
For evaluation on its Vehicle Dynamics Area, flooded to 0.050 inch with water, Goodyear provided three convertible Corvettes equipped with automatic transmissions. One Vette wore Goodyear Eagle F1 GS D3, one wore Michelin Pilot Sport and one Bridgestone Potenza S-03 tires. Though the cars were theoretically identical, they were rentals and could have had some differences.
In a braking test, the numbers indicated the Michelin third, Bridgestone second and Goodyear first, inverse of the order in which we drove them. Interestingly, we didn't feel the ABS pulsing for the last third of the stopping distance with the Goodyear.
On the wet autocross, journalists were firmly instructed to drive in second gear with the Traction Control System on line. The Goodyear worked well and showed a gradual, forgiving nature. The tire was also well matched to the Corvette's TCS, which intervenes very late, and allows the driver to get sideways. The Michelins slid more and sooner than the Goodyears, and the car was a bit tail-happier. The Bridgestones slid the most."
Old Mar 20, 2007 | 12:18 AM
  #34
Pewter 01's Avatar
Pewter 01
some pics too please. I want to check out the profile on them
Old Mar 20, 2007 | 12:49 AM
  #35
mikexxxx's Avatar
mikexxxx
I've had 2 sets of kumho asx's. One set on thin spoke c5 rims which have been balanced 2x times with a hunter machine. With a lot of weight they are close but still have a consistent non-solid feeling about them. The other set was on an o6 mini cooper s which was balanced 3x times using a hunter machine. These tires flat out vibrate...I believe a tire is out of round. At present I've got one set of michelin's Exalto's on after market mini rims with less than 1oz of weight per tire and are spot on. My brother was a tire tech until he got his ase mechanics rating and swears by michelins. I've also had 3 sets of GY d3's, 2 on the vette and one set on the mini which all balanced up well and handle arguably the best but I found a bit stiff walled and noisy, there's always a compromse. I've decided to bite the bullet and buy ps2's for the vette, can you guess why?
Old Mar 20, 2007 | 10:35 AM
  #36
hotrod03's Avatar
hotrod03
I will do it man
Old Mar 20, 2007 | 11:55 AM
  #37
SocalChvy's Avatar
SocalChvy
I love Kumhos
To Kumho Tires?
Old Mar 20, 2007 | 12:57 PM
  #38
78-Bandit's Avatar
78-Bandit
Active Streak: 90 Days
Originally Posted by rws.1
Made in Korea...
non union
very low wages
their economy is based on cash flow not profit...
Don't forget no bull **** OSHA rules,
no workman's comp,
no employee lawsuits...
BTW, I love my Kumho Ecsta MXs
Old Mar 20, 2007 | 01:05 PM
  #39
SSWEET's Avatar
SSWEET
Rather than reading Kuhmo bashing from those that went out and spent big bucks for other tires...I'd like to see comments from those that actually run Kuhmo's now. And how they feel the Kuhmo's stack up to their previous tires..Best people to have a take on Kuhmo's are the people who have them!!!
Old Mar 20, 2007 | 01:33 PM
  #40
techboy's Avatar
techboy
I have them on my everyday driver great tires and very reasonable priced
