another tire / wheel sizing question
Old Mar 24, 2007 | 12:37 AM
wamara's Avatar
wamara
Cruise-In II Veteran
thug29,
Just consider this; GM puts a 275 width tire on the 9.5" wide wheel, and a 295 tire on a 10.5" wheel....
275/35-19 is a straightforward plus one sizing from a 275/40-18, but you're going with a wider wheel now. How it looks aside, does the tire mfr. recommend this size on your width wheel? And even if it's within allowed parameters, if it's at one end of the range, I suspect it would not be considered ideal.
Old Mar 24, 2007 | 07:10 AM
thug29's Avatar
thug29
So what are you trying to say...stay with the 275/35/19 rear tires on my 19x10.5 wheel or am I able to bump it up to a larger size tire? Can I go 285, 295 ....? And for the height, stay at 35 or go down to 30 ???
Thank you very much.
Old Mar 24, 2007 | 08:16 AM
SS~7's Avatar
SS~7
No Question! Do 305's
Old Mar 24, 2007 | 02:23 PM
edensknight's Avatar
edensknight
Originally Posted by JETZ
I'd go for the 305's!
Of course you would, FRANKAAAY!
And, yes, for an o.e. based C5 rear wheel offset (a C5 with an C5 o.e. positive offset wheel design in mind), an ideal tire width size for an 10.5 inch wide rear wheel IS an 305mm tire. Moreover, as it is imperative that you properly match tire width sizes to appropriate ideal wheel widths, it is also important to consider the actual wheel offset of the specific wheel chosen for your application when selecting custom aftermarket wheels. Enjoy!
Old Mar 24, 2007 | 02:49 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Originally Posted by wamara
IMHO that is too narrow. I would go with a 295 or 305 width tire.
Old Mar 24, 2007 | 07:19 PM
thug29's Avatar
thug29
Thanks guys I appreciate your knowledge...I will look into upgrading to at least 295
Old Mar 24, 2007 | 10:59 PM
JETZ's Avatar
JETZ
Words of wisdom AKA endensknight!
Old Mar 25, 2007 | 03:37 AM
thug29's Avatar
thug29
Well I'm back to square one....found out that the tires I ordered don't come in either 295 or 305 so I'm basically stuck with what I've got.
Old Mar 25, 2007 | 03:51 AM
JETZ's Avatar
JETZ
Should have done your homework before, you can still send em back for a different brand in those sizes!
Old Mar 25, 2007 | 06:55 PM
thug29's Avatar
thug29
I guess I could call but I have read that these tires are suppose to be one of the better ones on the market ??? Who knows....
