Do I Have a Bladder Control Problem?
Old Mar 22, 2007 | 04:16 PM
toxdoc's Avatar
toxdoc
Default Do I Have a Bladder Control Problem?
Hi all,
On my sport seat, driver's, the 3 little control switches for the lumbar support bladder inflation / deflation do nothing. This is not my concern; I don't give a darn about that lumbar support working or not.
The issue is that I notice that about every minute or so, it sounds like the pump is trying to run for a few seconds. All by itself. Even when parked and key is off. I'm concerned about possible battery drain from this.
Has anyone else had this issue? Is there a separate fuse or disconnect for just the bladder pump, leaving the seat motor operational? Thanks.
Old Mar 22, 2007 | 05:12 PM
LMB-Z's Avatar
LMB-Z
I have the same problem. Hope someone can answer this question.
Old Mar 22, 2007 | 05:19 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Try some Depends, problem solved.
Old Mar 22, 2007 | 05:20 PM
slverc5's Avatar
slverc5
Have you seen a Urologist - maybe you have a urine infection. I apologize I have to be the one to make the jest. But seriously though, hopefully you get your power seat problem solved.
Old Mar 22, 2007 | 05:25 PM
toxdoc's Avatar
toxdoc
Yes, but when I told him "I have a problem with where I sit" he sent me off to the proctologist!
Old Mar 23, 2007 | 12:25 AM
skylark's Avatar
skylark
My 97 builds up moisture inside and the seat switches go nuts ! I get them where I like them and then unplug them .
Old Mar 23, 2007 | 01:15 AM
toxdoc's Avatar
toxdoc
Great! Very helpful, thanks. I'd guess the disconnects are the typical Molex type somewhere under the seat or under the carpet, but I haven't gone digging for them yet. Is that where I find them? Thanks again.
Old Mar 23, 2007 | 07:14 AM
Sounds like you have a short somewhere and that is causing your air pump to work even when you do not use the switch. There are a couple of connectors under the seat and maybe one of them controls the lumbar power.
Old Mar 24, 2007 | 04:10 AM
skylark's Avatar
skylark
The wires on mine come up the outside edge of the seat under the track and plug right into the back of the switch .
Old Mar 24, 2007 | 04:36 AM
DeeGee's Avatar
DeeGee
The switches are mounted on the seat and the electrical connection is right behind the seat track
Run down to step 4 on this how to from Vette Essentials:
http://www.vetteessentials.com/instr...er_change.html
You can see how the connector fits together. It may be that cleaning that up and re-seating it could fix it. If not, it may be a switch change to solve the problem.
To Do I Have a Bladder Control Problem?
