Catch cans... Help me understand.
Old Mar 30, 2007 | 04:18 PM
darb21's Avatar
darb21
Default Catch cans... Help me understand.
So the catch cans... I know that if I ask a question here wether or not you need one, 99/100 folks will say that I do need one. I've got an '02 coupe with somehwere between 13 and 14 thousand miles on it, and am debating the catch can.
So a couple of questions...
1.) What problem does having one of these cans prevent?
2.) Where can I look to see symptoms that I do/do not need one?
Thanks,
Brad
Old Mar 30, 2007 | 04:48 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Thanks,
Brad
1st: Read this and learn about Positive Crankcase Ventilation
Much of the "blow by" is being sent into your intake on the LS1 and LS6.
The catch can "catches" this blow by between the PCV valve and the intake and collects it in the can which you can clean out ocassionally.
Old Mar 30, 2007 | 05:24 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Theory is that if you don't drive hard you probably don't need it. On the other hand I just saw a posted photo of the inside of an intake that supposedly hadn't been driven hard and it was full of oil mist.
It isn't at the top of my "mod" list but that photo moved it up several notches.
If you drive hard, get it soon. If not, wait with me for the next Group Purchase discount.
JMHO
Old Mar 30, 2007 | 06:04 PM
idenphones's Avatar
idenphones
Cruising
Corvettes are not alone in this problem. Looks like it might be a GM trait!
I bought a 2007 GMC Acadia about 1 month ago. It is not even broken in yet.
I pulled the airfilter box out today to see about giving it some additional cold air and guess what I found?
The accordian tubing from the throttle body to the mass airflow sensor was full of oil!
Looks like it is time to put a Catch Can on this vehicle as well.
Old Mar 30, 2007 | 06:06 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Mar 30, 2007 | 08:00 PM
VetteBandit's Avatar
VetteBandit
Does anyone have a picture of their catch can on the car. I have always heard about them on the vette, but never see anyone with them. All this talk recently has got me thinking I should put one on. Just dont want it to be an eye sore under my hood. Thanks in advance.
Old Mar 30, 2007 | 08:24 PM
ter's Avatar
ter
Follow wthis link:
http://forums.corvetteforum.com/show...ighlight=catch
Willfulone has pictures on his web page.
I just got one from him, I will put it in this weekend. It looks like a quality unit.
Old Mar 30, 2007 | 08:49 PM
stevedun's Avatar
stevedun
Cruise-In 8-9-10-12 Veteran
I don't drive real aggressive most of the time. I have an '01 Z06. I bought and installed the catch can after reading all the post about the oil in the intake and it's possible effect on the mass air flow sensor and other sensitive engine parts. I was like you in questioning whether it was necessary with my style driving. I mostly drive the speed limit with the occasional spirited driving and only occasional high rpm range (hard not to when you drive a vette). I checked mine after it was installed for one month and it did contain about 2 oz. of oil that would have been in my intake. It looks like it belongs so it is not engine clutter. I bought the red one from Elite Engineering to go with my QS. Not unhappy or regret it at all. It does what it was designed to do.
Old Mar 30, 2007 | 08:57 PM
Old Man in a C's Avatar
Old Man in a C
Originally Posted by ter
Follow wthis link:
That's a great looking product. Beautiful machining.
However, it's bling in my opinion. For my style driving, the LS1 happily digests any blowby.
Flame away at will.
Old Mar 30, 2007 | 09:22 PM
Z28TOZO6's Avatar
Z28TOZO6
Does the 01 z oil burning problem increase the value of the catch can if the piston oil rings havent been changed?
Old Mar 30, 2007 | 09:31 PM
stevedun's Avatar
stevedun
I would not think so, but don't know for sure. My '01 is not an oil burner as I easily make it to 3000 miles without adding any oil. I would think that oil blowing by the piston rings is different from what would be caught by the catch can.
RonJ's Avatar
RonJ
Flame away at will.
A bit of upper cylinder lube never hurt! Bling in most cases.
RonJ ...
Old Mar 30, 2007 | 09:32 PM
Glennm27's Avatar
Glennm27
Old Mar 30, 2007 | 10:07 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
That's a great looking product. Beautiful machining...
Thanks lukeee
Peace
Chip
__________________
..................Click for
Old Mar 31, 2007 | 12:45 AM
Dave68's Avatar
Dave68
Here's everything you need to know:
http://www.conceptualpolymer.com/PCV...oval%20101.pdf
....and more.....
Old Mar 31, 2007 | 12:54 AM
pala's Avatar
pala
St. Jude Donor '07
Flame away at will.
I thought i was going to need one but
i dont think it is a issue with the 03 and 04.
Old Mar 31, 2007 | 01:30 AM
ALLEGRO's Avatar
ALLEGRO
I don't hammer my AE very much at all. I read about the catch can and decided to make my own. The end of a long story is that I get a couple ounces of oil every month. I only have 22K on the clock and I think that this amount is a bit much.
My opinion is to get one, how can it hurt?
To Catch cans... Help me understand.
Old Mar 31, 2007 | 01:50 AM
pala's Avatar
pala
St. Jude Donor '07
mmmmm. i dont know,i think i am still on the fence on this issue,
i just put my first 5,000 miles (15k total) on my 04 with and used less then a 1/3 of a quart of oil.
Old Mar 31, 2007 | 02:04 AM
ALLEGRO's Avatar
ALLEGRO
I don't think you can judge the need by oil consumtion. Most of the oil goes into the intake in a near fume state. As it slows and makes significant contact it begins to re-liquify and puddle.
What my pictures don't include is that I added an inline paper filter (see thru design) after the can to see how much gets past. I still get significant discoloration in the paper but no puddling inside the filter.
To be honest, I did it just to see what effect it made, and in that I built my own for well under $30 it is painless.
Old Apr 1, 2007 | 05:21 PM
93LT1's Avatar
93LT1
Thank you Dave... Great write up.
....and more.....
