Amsoil
Old Apr 3, 2007 | 10:13 AM
z28flash's Avatar
z28flash
Default Amsoil
Has anyone used Amsoil in their vehicle? And/or done a UOA (used oil analysis)? Amsoil is not cheap, running around $7 quart, but I have used it with success in my motorcycle, so just wondering if anyone was satisfied with it.
I get my new wheels/tires this weekend, and I'll post some pictures after!
Old Apr 3, 2007 | 12:08 PM
GUSTO14's Avatar
GUSTO14
I have used AmsOil in all of my rear ends and gearboxes for more than 20 years without any problems so far. I've also been using AmsOil in my Diesel Ford since new in 2001 and even with 15 quart oil changes, consider it worth every penny.
I've been using Mobil 1 in my Corvettes since the mid 80's and have no complaints either. As long as you're using a good quality synthetic, I doubt you would be able to discern a difference without an oil analysis, which isn't a bad idea itself!
Taking care of them now is always cheaper than repairing them down the road.
Good luck... GUSTO
Old Apr 3, 2007 | 12:32 PM
VetteBandit's Avatar
VetteBandit
Amsoil in the grear box of my 85, mobile 1 on th 02. Amsoil is very good stuff, especially on older trannies. I think mobile 1 is top notch as well.
Old Apr 3, 2007 | 01:08 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Aimsoil in all of my cars now
Just wanna save the enviroment by not changing oil every 3K miles but then I don't have cats
Old Apr 3, 2007 | 01:16 PM
z28flash's Avatar
z28flash
Default thanks, and maybe I'll do the UOA findings
Thanks to all....think even though it is more expensive I'll try the Amsoil this time. It really quieted down my motorcycle when I used it (I have a Honda VTX 1300).
For the heck of it, if I do the UOA, I'll let everyone know how it went; sounded interesting but I don't think it's really necessary.
Let ya'll know how it goes!
Old Apr 3, 2007 | 01:54 PM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
I am waiting to get as close to 8,000 miles on my oil change to send in the oil for analysis. I will post up once this is done. I have used Amsoil in my Z for two years now. I use the synthetic 10W-30 motor oil the Synthetic ATF and the 75-90 rear Severe gear oil. If you become a prefered dealer you can save money on your purchases. Try to PM Brad aka Subdriver on the forum here. He can set you up. Don
Old Apr 3, 2007 | 02:21 PM
MiamiCowboy's Avatar
MiamiCowboy
I run Amsoil in all my vehicles.(ZO6, 07 Sierra 6.0 and Pontiac GTP) The product is a bit more expensive but then I do not change my oil every 3,000 miles. I go every 6 months or 5,000 miles. Even at that interval the oil is remakably clean looking. Yes, the oil is a little more expensive than others but I did not buy my Corvette ZO6 with saving money on oil changes in mind. As a preferred Amsoil customer I get a discount and it brings the cost down to a couple of dollars more than Mobil 1 per quart. The wear test and history of Amsoil justify the added expense and sense of security I get from using the Amsoil lubricants and filters.
Brad Neff aka subdriver provided me with a lot of solid information and guidance in making the switch. I am happy I did.
Old Apr 3, 2007 | 02:29 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Amsoil is the best. Thats why its in my car
here are my oil test results:
Old Apr 3, 2007 | 09:19 PM
scottydog's Avatar
scottydog
Amsoil is great oil. Go on BITOG and you will see.
However I don't believe it has been certified as meeting GM4718M spec, so you could void your warranty if you're still covered.
Penzoil Platinum 5w-30 is on the approved list, as is getting good reviews on BITOG. Mobil1 gets +/- comments, ok but there are concerns about it now being group 3, and questions about the new formulation.
Old Apr 3, 2007 | 10:45 PM
vettes4fun's Avatar
vettes4fun
I'm using Amsoil in my vettes, my Hummer and my Harley.
Old Apr 4, 2007 | 09:29 AM
old stingray's Avatar
old stingray
I also use Amsoil in my vettes and Harley,but my hummer...well she really doesn't care for the taste!
Old Apr 4, 2007 | 09:50 AM
oldschoolvette's Avatar
oldschoolvette
I have used it for 15 years and love it. I have also used the UOA. worth every penny
Old Apr 5, 2007 | 12:56 PM
dwjz06's Avatar
dwjz06
Dogface
The 5W-30 and the 10W-30 both meet the GM spec 4718M. I have used both. Don
Old Apr 5, 2007 | 03:52 PM
Patman's Avatar
Patman
For those of you under warranty still, you want to remember one important factor. There is a difference between an oil meeting 4718M, and an oil that is registered by GM for 4718M. See the picture below:
Old Apr 5, 2007 | 03:56 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Apr 5, 2007 | 04:05 PM
427435's Avatar
427435
I beg to differ. Where does Amsoil (or GM) say that the Amsoil MEETS the GM Spec??????
Amsoil, in their typical slippery manner, just says that they (Amsoil) RECOMMENDS these oils for the GM spec-----------they don't say that the oils ACTUALLY MEET the spec------nor do they get actual API certification.
If you care about your Vette, use an oil that is actually certified to meet the GM specs!!!!
Old Apr 5, 2007 | 07:28 PM
dwjz06's Avatar
dwjz06
Dogface
As an educated man or engineer as you have listed yourself the above statement is pretty lame.
You think I do not care for my car because of a well chosen oil product.
I think you better do your research before you call someone out. You do understand meets or exceeds right! or if not you can read the full page links below.
These are the links for the following oils.
Engine Oil:
AMSOIL Series 2000 0w30
AMSOIL SAE Synthetic 5w30
AMSOIL SAE Synthetic 10w30
http://www.c66racing-synthetics.com/...tins/TSOPB.htm
http://www.c66racing-synthetics.com/...tins/ASLPB.htm
http://www.c66racing-synthetics.com/...tins/ATMPB.htm
The 5W-30 gets the following ratings:
APPLICATIONS
AMSOIL Synthetic 5W-30 Motor Oil is recommended for use in gasoline engines and other applications requiring any of the listed worldwide specifications:
API SM/CF, SL, SJ ...
ILSAC GF-4- 3 ...
ACEA A5/B5
JASO VTW
GM 4718M, 6094M
Ford WSS M2C929-A
Daimler Chrysler MS-6395N
VW 503.00, 505.00
To Amsoil
Old Apr 5, 2007 | 07:46 PM
LoneStarFRC's Avatar
LoneStarFRC
Amsoil Series 2000 0W-30. Change every 9000-10000 miles.
Old Apr 6, 2007 | 12:00 AM
427435's Avatar
427435
Engine Oil:
APPLICATIONS
ILSAC GF-4- 3 ...
ACEA A5/B5
JASO VTW
GM 4718M, 6094M
Ford WSS M2C929-A
VW 503.00, 505.00
Look (and carefully read) the links you posted!! Amsoil does claim, in the first link for 0w-30 oil, that this oil meets the specs listed. Sorry, I only checked Amsoil's claims for the 5w-30 viscosity oil that GM recommends. However, I still don't see any API certification for this 0w-30 oil.
Then, in your next 2 links, Amsoil falls back on their usual recommended statement----which isn't worth anything when you have a warranty claim.
When there are so many fully API certified, NOT TO MENTION GM APPROVED oils out there, from very reputable companies (that don't play word games and that don't ignor API certification), why go with a company that does both????
I also find it amusing that Amsoil uses Mobil 1 as their point of reference----kind of like all the guys that like to say their car is faster than a Vette.
Old Apr 6, 2007 | 12:05 AM
1stTimeVette's Avatar
1stTimeVette
Have any of you tried NEO? I have used it for years after Amsoil changed their formula years ago. NEO is formulated in Long Beach, CA and it is a true di-ester based synthetic. Visit them at www.neosyntheticoil.com Tell PJ that you got this tip on Corvette Forum.
Neo is the best oil I have found. From trannys, gearboxes and fuel additives. Even a terrific hand cleaner.
