please read now@!@@@!!!!
Old Apr 5, 2007 | 03:15 PM
omarcoolguy's Avatar
omarcoolguy
Originally Posted by C5 KIDD
im sure your fine. you would know if something messed up!
something is messed up;.....i just wanna see if any one had personal experiences
Old Apr 5, 2007 | 03:17 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
"and the temp reached up to 245"
I believe there was a post on the CF and there are web sites that say that temps above 225 degrees let's the tranny run for 3 to 5k before the oil should be changed. I'll see if I can find the information and post it here.
This is what I couold find:
As a rule of thumb, every 20 degree increase in operating temperature above 175 degrees F. cuts the life of the fluid in half!
At 195 degrees F., for instance, fluid life is reduced to 50,000 miles. At 220 degrees, which is commonly encountered in many transmissions, the fluid is only good for about 25,000 miles. At 240 degrees F., the fluid won’t go much over 10,000 miles. Add another 20 degrees, and life expectancy drops to 5,000 miles. Go to 295 or 300 degrees F., and 1,000 to 1,500 miles is about all you’ll get before the transmission burns up.
If you think this is propaganda put forth by the suppliers of ATF to sell more fluid, think again. According to the Automatic Transmission Rebuilders Association, 90% of ALL transmission failures are caused by overheating. And most of these can be blamed on worn out fluid that should have been replaced.
On most vehicles, the automatic transmission fluid is cooled by a small heat exchanger inside the bottom or end tank of the radiator. Hot ATF from the transmission circulates through a short loop of pipe and is thus "cooled." Cooling is a relative term here, however, because the radiator itself may be running at anywhere from 180 to 220 degrees F.!
Tests have shown that the typical original equipment oil cooler is marginal at best. ATF that enters the radiator cooler at 300 degrees F. leaves at 240 to 270 degrees F., which is only a 10 to 20% drop in temperature, and is nowhere good enough for extended fluid life.
Any number of things can push ATF temperatures beyond the system’s ability to maintain safe limits: towing a trailer, mountain driving, driving at sustained high speeds during hot weather, stop-and-go driving in city traffic, "rocking" an automatic transmission from drive to reverse to free a tire from mud or snow, etc. Problems in the cooling system itself such as a low coolant level, a defective cooling fan, fan clutch, thermostat or water pump, an obstructed radiator, etc., will also diminish ATF cooling efficiency. In some cases, transmission overheating can even lead to engine coolant overheating! That’s why there’s a good demand for auxiliary add-on transmission coolers.
Auxiliary Cooling
An auxiliary transmission fluid cooler is easy to install and can substantially lower fluid operating temperatures. The plate/fin type cooler is somewhat more efficient than the tube and fin design, but either can lower fluid temperatures anywhere from 80 to 140 degrees when installed in series with the stock unit. Typical cooling efficiencies run in the 35 to 50% range.
Atf Fluid Types
What kind of automatic transmission fluid should you use in your transmission? The type specified in your owner’s manual or printed on the transmission dipstick.
For older Ford automatics and certain imports, Type "F" is usually required. Most Fords since the 1980s require "Mercon" fluid, which is Ford’s equivalent of Dexron II.
For General Motors, Chrysler and other imports, Dexron II is usually specified.
NOTE: Some newer vehicles with electronically-controlled transmissions require Dexron IIe or Dexron III fluid. GM says its new long-life Dexron III fluid can be substituted for Dexron II in older vehicle applications.
CAUTION: Using the wrong type of fluid can affect the way the transmission shifts and feels. Using Type F fluid in an application that calls for Dexron II may make the transmission shift too harshly. Using Dexron II in a transmission that requires Type F may allow the transmission to slip under heavy load, which can accelerate clutch wear.
Changing The Fluid
It’s a messy job because there’s no drain plug to change the fluid, but you can do it yourself if you’re so inclined. To change the fluid, you have to get under your vehicle and remove the pan from the bottom of the transmission.
When you loosen the pan, fluid will start to dribble out in all directions so you need a fairly large catch pan. You should also know that removing the pan doesn’t drain all of the old fluid out of the transmission. Approximately a third of the old fluid will still be in the torque converter. There’s no drain plug on the converter so you’re really only doing a partial fluid change. Even so, a partial fluid change is better than no fluid change at all.
A typical fluid change will require anywhere from 3 to 6 quarts of ATF depending on the application, a new filter and a pan gasket (or RTV sealer) for the transmission pan. The pan must be thoroughly cleaned prior to reinstallation. This includes wiping all fluid residue from the inside of the pan and scraping all traces of the old gasket from the pan’s sealing surface. Don’t forget to clean the mounting flange on the transmission, too.
When the new filter is installed, be sure it is mounted in the exact same position as the original and that any O-rings or other gaskets have been properly positioned prior to tightening the bolts. Then tighten the bolts to the manufacturer’s recommended specs.
When refilling the transmission with fresh fluid, be careful not to allow any dirt or debris to enter the dipstick tube. Using a long-neck funnel with a built-in screen is recommended.
CAUTION: Do not overfill the transmission. Too much fluid can cause the fluid to foam, which in turn can lead to erratic shifting, oil starvation and transmission damage. Too much fluid may also force ATF to leak past the transmission seals.
Add half a quart at a time until the dipstick shows full. The transmission really isn’t full yet because the dipstick should be checked when the fluid is hot, and the engine is idling with the gear selector in Park. So start the engine, drive the vehicle around the block, then recheck the fluid level while the engine is idling and add fluid as needed until the dipstick reads full.
Old Apr 5, 2007 | 03:23 PM
corvettejimw's Avatar
corvettejimw
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '08
Originally Posted by MyVetteDream
I had to go to a bigger monitor just to type that....
Old Apr 5, 2007 | 03:25 PM
BAMF AE's Avatar
BAMF AE
From: The Surgeon General has warned that it's ok to smoke mustangs!
St. Jude Donor '06-'07
I've driven another car with almost half the oil "missing" (wasn't my car)...
My advice would be if you can avoid "hard driving" then just don't do it... I didn't have any issues except when I noticed the pressure/tempreture changes...
ROFLMAO!!!!!!!!!!!!!
You crack me up brutha! I'm dyin laughin over here!
Old Apr 5, 2007 | 03:39 PM
corvettejimw
St. Jude Donor '08
Ok I see now...
Old Apr 5, 2007 | 03:43 PM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
Originally Posted by corvettejimw
Ok I see now...
Old Apr 5, 2007 | 03:47 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Regardless of how you got to your current situation ... if your transmission is slipping, you've got a problem.
max'svette's Avatar
max'svette
St. Jude Donor '11
245 F? What the hell were you doing? The total capacity is 11 quarts so 1-2 quarts low although not good shouldn't destroy a transmission. But it may have added to the heat.
I would be MORE worried about that temperature. You should NEVER run automatic transmission above 210F. It fried all internal rubber parts as well as clutches at that temperature. Why didn't you pull the car over and let it cool off?
Old Apr 5, 2007 | 03:51 PM
photoguy's Avatar
photoguy
If you know for a fact that it is messed up...then I would get it fixed!!
Old Apr 5, 2007 | 04:04 PM
M6 Vetter's Avatar
M6 Vetter
Exactly
Old Apr 5, 2007 | 05:01 PM
R Devil's Avatar
R Devil
WTF?
Old Apr 5, 2007 | 05:08 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Ok I see now...
What's funnier is I ACTUALLY had a 32" monitor around Christmas... dang thing gave me a headache, so I just put it in my GF's living room.
Old Apr 5, 2007 | 05:23 PM
  #33
dano99vert's Avatar
dano99vert
St. Jude Donor '13-'14-'15-'16
Default trans
Omar, once trans starts slipping in these cars, they are Done!!!, 3/4 clutch pack is weak, if it was slipping in 3/4 it more that likely burned that pack, I would suggest calling Rodney at RPM transmission and ask his professional opinion, I just went thru this and when my trans was rebuilt we found 3/4 clutch pack smoked!!! and it was only 1 1/2 qts low. Call RPM trans NOW!!! GOOD LUCK
Old Apr 5, 2007 | 06:02 PM
  #34
JLA's Avatar
JLA
From my recollection on previous posts, Omar seems to be constantly stepping in poo poo and can't figure out why his shoes stink.
Old Apr 5, 2007 | 06:06 PM
  #35
Jet-Jock's Avatar
Jet-Jock
I don't know about RPM Trans, but
If it was just low fluid, high temp and nothing else probably a bad smell like burnt fluid would be one thing. You could have flushed and replinished the fluid and hope. But slipping then you have clutch pack problems, plus unknown other problems until it is opened up.
Must be more to this story my guess involves Zippy Lube.
Old Apr 5, 2007 | 07:20 PM
  #36
omarcoolguy
Edit Read First
Old Apr 5, 2007 | 07:31 PM
  #37
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Omar, seems that every time I read one of your threads that there is some kind of crisis.
Oh wait, there were a couple of cool pic threads and one with some hotties.
IMHO, if Jiffy Lube damaged your transmission, then they should pay for a new one.
Good luck.
To please read now@!@@@!!!!
Old Apr 5, 2007 | 08:12 PM
  #38
Jet-Jock's Avatar
Jet-Jock
70,000 on a 2000 transmission, no your not going to get a brand new transmission. Sorry.
A GM rebuilt, which generally has a limited warranty, will be probably a reasonable restitution.
Old Apr 6, 2007 | 07:07 AM
  #39
Hopefully there is no damage. Since the shop owner is already aware of the potential issue, go ahead and put fluid back in and see if things work OK. Then go from there.
Old Apr 6, 2007 | 11:05 AM
  #40
omarcoolguy
they did top it off.....but it was to late the trans wouldnt shift.....
