please read now@!@@@!!!!
Old Apr 5, 2007 | 12:46 PM
omarcoolguy's Avatar
omarcoolguy
Default please read now@!@@@!!!!
will post new thread with updates soon have my car back now
Old Apr 5, 2007 | 12:53 PM
Mr. Jones's Avatar
Mr. Jones
don't know
thats less than one quart
fill it and see
Old Apr 5, 2007 | 12:57 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Apr 5, 2007 | 12:58 PM
photoguy's Avatar
photoguy
Old Apr 5, 2007 | 01:06 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I've driven another car with almost half the oil "missing" (wasn't my car)...
My advice would be if you can avoid "hard driving" then just don't do it... I didn't have any issues except when I noticed the pressure/tempreture changes...
Old Apr 5, 2007 | 01:11 PM
omarcoolguy
Originally Posted by Mr. Jones
don't know
fill it and see
it says 1 1/2 to 2 quarts...........more then a quart????i isnt it
Old Apr 5, 2007 | 01:18 PM
corvettejimw's Avatar
corvettejimw
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '08
I can't see this type!!
Old Apr 5, 2007 | 01:22 PM
MyVetteDream
I had to go to a bigger monitor just to type that....
Old Apr 5, 2007 | 01:25 PM
5ltrEATER's Avatar
5ltrEATER
Originally Posted by omarcoolguy
please respond ......CAN A C5 TRANSMISSION BE DAMAGED RUNNING IT 1 1/2 TO- 2 QUARTS LOW....... FOR 1 DAY OF HARD AND SOFT DRIVING 20 MILES OR SO.......PLEASE GIVE ME YOUR RESPONSE OR PERSONAL EXPERIENCE THANK YOU......AND IF U READ THIS JUST LEAVE A COMMENT ON WHAT U THINK!
Depends on many factors... How many miles on the car/transmission, clutch condition, trans temp at time it was run low on fluild.
I wouldn't doubt that 1 1/2 - 2 quarts can screw up your tranny if it's got high-hard miles, high temps, etc.
I'm assuming you're talking an A4 based on fluid question, right?
Old Apr 5, 2007 | 01:28 PM
C5 KIDD's Avatar
C5 KIDD
Cruise-In VI Veteran
im sure your fine. you would know if something messed up!
Old Apr 5, 2007 | 01:39 PM
VinnyT's Avatar
VinnyT
Omar, dude, we've been over this already. Running the tranny with that low of fluid WILL damage the tranny. Your symptoms are the clue to a damaged trans. It's toast. Jiffy Lube has wrecked your trans. Try and file a claim and pray.
Old Apr 5, 2007 | 01:43 PM
omarcoolguy
i know.....i just talked to a mechanic...at gm....and he claims the car can run 2-quarts low without damaging the car.......so i just want to see everyones take on it....
Old Apr 5, 2007 | 01:50 PM
VinnyT's Avatar
VinnyT
But you didn't post ALL the info. Didn't you say you had the fluid topped off and it still slips? Then, yes, time for a rebuild.
Old Apr 5, 2007 | 01:54 PM
FactoryRaceCar
FactoryRaceCar
Screen=Monitor=Priceless
Old Apr 5, 2007 | 02:01 PM
ruf455's Avatar
ruf455
Holy huge text!
Old Apr 5, 2007 | 02:16 PM
rws.1's Avatar
rws.1
If everyone used this size, I wouldn't need my reading glasses any more...didn't I read that the tranny is slipping after top up? if true you know the answer...
To please read now@!@@@!!!!
Old Apr 5, 2007 | 02:21 PM
B-rent's Avatar
B-rent
I ran my first car a weekish with no oil in it I always turned up my music right when I got it so I never noticed the ticking noise but its done fine and that was a few years ago
and now i see you ment tranny fluid.....sooo no help there
Old Apr 5, 2007 | 02:22 PM
VinnyT's Avatar
VinnyT
Rule 'o Thumb:
-Running trans with low fluid - BAD
-Running trans with low fluid & high-temp warning light - WORSE
-Topping off trans and still slipping - FUBAR
Old Apr 5, 2007 | 02:50 PM
VetteFanatic007's Avatar
VetteFanatic007
