Splash Guards or Mud Flaps
Apr 11, 2007 | 05:11 PM
Any one using Mud Flaps Or Splash Guards on rear tires?
Like to know where to get ?
Dont like ones that ive seen so far .
Thxs
Apr 11, 2007 | 05:41 PM
Apr 11, 2007 | 05:53 PM
YOur going to get a ton of
for even asking this question.
mud flaps belong on trucks not cars
Apr 11, 2007 | 06:07 PM
If you can get them to look the way they do on the C6 Z06 then go for it. Otherwise Id suggest to not do it. But thats my personal opinion.
Apr 11, 2007 | 06:12 PM
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Apr 11, 2007 | 06:18 PM
Yes im looking for theC6 Z06 type
notta peterbuilt
Apr 11, 2007 | 06:20 PM
I like the flaps, I think they give the car a wider and lower looking stance.
Mine are Altecs and you can buy them at MidAmerican Motorworks.
Good luck and ignore the negative comments, it is your Vette not theirs.
Apr 11, 2007 | 06:21 PM
Here's what I have on my other chevy...
Later . . . . . .
6 Shooter
Apr 11, 2007 | 07:56 PM
Quote:
Originally Posted by
stormrider
they look good thxs
Apr 11, 2007 | 08:45 PM
See my sign, C6 Z06 rear fender guards is a nice alternative
Apr 11, 2007 | 08:47 PM
BT-01-vette
if you're gonna do it, C6 Z06 is the only way to do it.
Apr 11, 2007 | 09:39 PM
Where can you find the C6 Z06 guards??
Apr 11, 2007 | 10:44 PM
you buy z06 flaps and mod them. It took me a couple of hours for first one. But they look great. Do a search.
Apr 11, 2007 | 10:47 PM
jdmvette
Those look good!
Apr 11, 2007 | 11:33 PM
BT-01-vette
Or try Cleartastic
http://store.tkoperformance.com/clpapr.html
Apr 12, 2007 | 01:09 AM
I used the Eckler's/Mid America plastic mud guards on my 97. Installed low enough they helped quite a bit in protecting the rockers, lower doors and the wheel well openings. However, they are some what stiff and tend to vibrate just enough that they left a mark in the paint at the top where the flap ended and behind the flaps at the lower end. Some tape placed behind the flaps fixed the problem on the lower end but nothing I did kept the upper end from marking the paint. As for looks most people really didn't notice them as they sort of blend in with the tires. So the question is do you want sand blasted wheel wells, rockers and lower door panels (which will happen to all C5s that are driven a few thousand miles) or do you want some black mud guards.
Bill
Apr 12, 2007 | 01:23 AM
jdmvette
damn cars looking good
Apr 12, 2007 | 01:25 AM
stormrider
i had those. terrible on a lowered car. i ripped the fronts right off on a bump
Apr 12, 2007 | 01:35 AM
I fitted the C6 Fender Guards
Heres a link to the How To I posted when I did the fit:
http://forums.corvetteforum.com/show...=fender+guards
Apr 12, 2007 | 07:59 AM
I'm running a set I got from Ecklers - part number 35190. They sure keep the rock chips off the side of the car.
