F45 Question
Old Apr 12, 2007 | 05:16 PM
MrLeadFoot's Avatar
MrLeadFoot
Default F45 Question
I need to test one of my front shocks by switching the shocks from one side to the other. Does anyone know how to disconnect the wire from the shock? For the life of me I can't seem to figure it out.
TIA
Old Apr 12, 2007 | 05:23 PM
LLVETTE's Avatar
LLVETTE
Follow the wire from the shock to the plug that lies on the frame of the car and disconnect it there. There will be about a 8 inch wire attached to the shock. Took me a little bit to figure it out also....
Old Apr 12, 2007 | 05:44 PM
MrLeadFoot's Avatar
MrLeadFoot
Thanks for the reply. So, the wire stays connected to the shock then, huh? No wonder I couldn't disconnect it at the shock!
Old Apr 12, 2007 | 05:59 PM
LLVETTE's Avatar
LLVETTE
Yep. I practically destroyed the shock the first time I did it trying to disconnect the wire from the shock.
Old Apr 12, 2007 | 06:01 PM
LLVETTE's Avatar
LLVETTE
By the way, I have a full set of F45 shocks that I took off my car, if you need any....
Old Apr 13, 2007 | 09:30 PM
MrLeadFoot's Avatar
MrLeadFoot
Thanks, I will keep that in mind if I find that the shock in question is bad.
To F45 Question
