Front Sidemarker Questoin
Old Apr 15, 2007 | 03:12 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Default Front Sidemarker Questoin
How do you replace the OEM front sidemarker bulb?
I can't believe I can't figure this one out.
What's the trick.
Thanks for your help in advance.
Glenn
Old Apr 15, 2007 | 03:16 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
The easiest way is to remove the access cover just in front of the wheel and under the front bumper cover .You will then see the two sets of wires for the DRLs and the side lights .You will need to lift the car some for better accesss
Manny......
Old Apr 15, 2007 | 03:22 PM
grunz95's Avatar
grunz95
Default front marker lights
What's the trick.
Glenn
Glenn, I just replace my front bumper light assemblies.
Get the front end of the car jacked up and install jack stands, its a little easy to access the panel if you remove the tires. The panel is just below the front air duct. It has 4 screws to remove it. You should be able to get your arm inside.
Gary
Old Apr 15, 2007 | 03:23 PM
chuck1026's Avatar
chuck1026
Cruise-In II Veteran
Manny should know... he JUST did it yesterday
Old Apr 15, 2007 | 03:43 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
Ya and I'm feeling the pain in my neck today
Old Apr 15, 2007 | 03:50 PM
BanditDude's Avatar
BanditDude
What's the trick.
Glenn
I did it via the lower access panel, which works well if you have ramps. You can also raise the headlights manually and remove the black plastic surround. You can then access them by reaching through the opening w/o raising the car.
Good luck.
Old Apr 15, 2007 | 03:54 PM
Spoon83's Avatar
Spoon83
Good luck.
but you can also push back the air duct and reach in thru there. thats the way I have done it b4
Old Apr 15, 2007 | 04:12 PM
DeeGee's Avatar
DeeGee
Glenn
Presuming you don't have forearms the size of Arnold's, its just the same as changing the DRL bulb.
I use the same method. Take off the black headlamp surround and reach around the headlights. I go in from the outside. Its a bit more of a reach but easily doable. It twists out anti clockwise.
Last time I did it, it took 3 minutes flat for both bulbs.
Old Apr 15, 2007 | 05:14 PM
Glennm27's Avatar
Glennm27
Thank you all. I appreciate the help.......
To Front Sidemarker Questoin
