MN6 Fluid, your pick?
Apr 23, 2007 | 11:14 AM
St. Jude Donor '07
I'd like to change my manual tranny fluid, any recomendations for better shifting when cold?
John
Apr 23, 2007 | 11:57 AM
2017 C7 of the Year Finalist
St. Jude Contributor
Apr 23, 2007 | 04:08 PM
I just changed mine this past week and the shifting is better and smoother. I used oriliey ATF Dextron III. My car is a 99. The oil capacity is 3.5 quarts. My total cost was under $10 to change the oil myself and mybe like 15minutes.
Apr 23, 2007 | 04:12 PM
I had Mobil 1 ATF in for 51,000 miles - good shifting until 6th starting grinding.
I then switched to Amsoil ATD - no complaints, solved 6th gear grind. I have 103,000 miles on my C5.
Go to a synthetic fluid, much better cold shifting.
Apr 23, 2007 | 04:18 PM
St. Jude Donor '11
So you guys are going with an automatic transmission fluid (ATF) in your manual tranny?
Is there a reason for this (i.e. better than a manual transmission fluid).
Apr 23, 2007 | 04:21 PM
Quote:
Originally Posted by
sgtzim
It is what is called out for this manual transmission.
Apr 23, 2007 | 06:34 PM
Apr 23, 2007 | 06:51 PM
I ran royal purple max atf for about 500 miles and did not like the harder shifting, switched to royal purple Sycromax and im never looking back
Apr 23, 2007 | 07:23 PM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Apr 23, 2007 | 07:43 PM
I can see we all agree again................................... .
Apr 23, 2007 | 10:39 PM
sgtzim... the specs for the MN6 manual transmisison require a Dexron III fluid....
any Dexron III ATF fluid will do...
Some claim the exotics like Redline, Amsoil or Royal Purple SynchroMax give smoother shifting..
Apr 23, 2007 | 10:42 PM
Apr 23, 2007 | 11:44 PM
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Royal Purple SyncroMax...
Peace
Chip
Apr 23, 2007 | 11:50 PM
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Black 'n Tan
John
AMSOIL ATF hands down. no issues here during NJ winter.
Apr 24, 2007 | 01:46 AM
St. Jude Donor '08
"the specs for the MN6 manual transmisison require a Dexron III fluid...." 'Tis true.
I did mine about 6 months ago and it is clearly stated via a sticker (at least on my '01) to use Dexron III ATF. The sticker was directly next to the drain. It was impossible to miss. I simply used the Delco Dexron III ATF fluid.
Doing so provided me with a much smoother shifting following the change and mine only had 25000 miles on it at the time.
Apr 24, 2007 | 02:14 AM
Redline full synthetic
I switched Dexron III to Redline D4 Synthetic ATF and was not suprised by the smoother gear action but was suprised that the tranny was quieter.
99 ,
amsoil ,
atf ,
c5 ,
capacity ,
corvette ,
fluid ,
maxatf ,
mn6 ,
syncromax ,
trans ,
z06
