Headlight gear help
Old Apr 25, 2007 | 12:21 PM
ls1vette97's Avatar
ls1vette97
Default Headlight gear help
Once again my headlight gear went bad, this time the left one. Believe it or not Autozone found me the gear for the motor, and it was actually manufactured by ford. I called them today, and they said that they did not carry the part. Does anyone know where I can get the plastic gear in southwest florida, or possibly have a part # for it?!?
Old Apr 25, 2007 | 12:46 PM
Oldvetter's Avatar
Oldvetter
If you disassemble the gearbox, you will see that only half of the gear is messed up. That is because you only use half of the gear. Note position of the gear and change it 180 degrees. Don't change the headlight position.
Presto, fixed for free !
Old Apr 25, 2007 | 01:37 PM
ls1vette97's Avatar
ls1vette97
Hey thanks for the info, I've heard that can work sometimes! It wouldn't be so bad if the damn gear didn't make a grinding noise for 10 seconds after u shut the lights off!!!!
Old Apr 25, 2007 | 04:36 PM
DeeGee's Avatar
DeeGee
If you're going to dismantle the motor fit a brass gear at the same time. Otherwise you'll be doing the mod again in 2 years time.
Look at Leftye's sticky at the top of the page. Run down to the section on headlight motor and its all explained there including a link to Rodney Dickmans website where you can get the parts.
Old Apr 27, 2007 | 05:04 AM
FiberglassFan's Avatar
FiberglassFan
http://www.rodneydickman.com/n113.html
Old Apr 27, 2007 | 06:36 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Originally Posted by FiberglassFan
best thing to do.. real easy..
To Headlight gear help
