I really like the "lip" on those wheels. How much do they weigh?
Front lip is 3", rear is 4", and I must say they look even better in person.
It's like I have a different car, I've had so many people shout compliments at me its unreal.
I liked the look of the polished thin spokes I had before but they were a little small for the car and they were starting to show some severe pitting as my car is a DD and here in the UK tonnes of rock salt are used each winter to keep the roads from freezing = this all means corrosion.
I may put the old thin spokes back on for use in winter.
I'm not sure what they weigh but I can tell you that it is not excessive, I did a crude comparison against stock thin spokes and they are not ridiculously heavy in comparison.
I got 19's (chrome 280's) all the way around... Also from Adriano on recommendation from ccajun4real here on the forum. Anyway, it was 38 lbs fr / 40 lbs rear for wheels and tires aired up according to the fedex label. Which still makes them almost identical in weight to my 17/18 wagon wheels with tires. So I wouldn't worry much about weight. Fit wasn't a problem on mine either, should have pics one of these days...
That's great! I need to look into getting a set of these...
It is cloudy and raining outside so the lights are from my garage
I have a small issue with 2 of the wheels and waiting for a response.
See where the paint goes past the edge here
It does not do that on the other 2, its a nice crisp line
I have emailed pics to the vendor to see, If i can get some money back and clean the paint off myself I may do it. Not sure what I could do though. It does not appear that the lip is clearcoated, would I just get some fine grit paper to clean it up?
This sucks because Discount Tire called and said my tires are in
