[Z06] So it does look like a 4X4...
). The 2002 Owner's Video can be found (broken into 5 parts) in the media gallery here: http://www.z06vette.com/media.php (Twil1ght posted the link a few days ago, so it's gotta be ok, right?
)The drop is mentioned in the 3rd video on or about the 31:40 timestamp.
Cheers!
Toque - great look but I couldn't drive that low around here. Well, I could but I'd get rear ended by trying to slow down and crawl over bumps and construction, etc. Plus entry/exit drives are not set up for low cars, I'm already taking those at steep angles from the drive lanes while at stock height.
SublimeZ - nice stance, should I decide to lower your's will be my benchmark.
The part on lowering the car is under the "Setting your Z06 up for Racing" section. I don't race my Z although day-to-day driving often seems like I'm qualiying for Sunday! I haven't heard the part in the video about the car is raised from the factory for shipping as mentioned in an earlier post. I need to watch all 5 parts. I also recognize the need to have the alighment done as lowering will affect handling and tire wear.
Hmmm, got some thinking to do. Our club is running the tail of the dragon next weekend. Wonder if I can get her lowered before then...
- handling will not suffer due to ride height as long as you don't go any lower than the stock bolts allow...
- optimal vehicle rake is approx 1/2" lower on the front than the back (I have also been told that this approx 1/2 degree toward the front)...
- daily driver handling and tire wear will be optimal for coupe caster/camber/toe settings, rather than the more aggressive Z06 settings...
- if you track the car alignment specs will be determined by the style of racing, and the poor off-track tire wear you are willing to incur...
C5 Service Manual Alignment
Front Individual Toe +0.04 degree
Front Sum Toe +0.08 degree
Front Individual Caster +6.9 degree
Front Cross Caster within 0.50 degree
Front Individual Camber -0.20 degree
Front Cross Camber within 0.50 degree
Rear Individual Toe -0.01 degree
Rear Sum Toe -0.02 degree
Rear Individual Camber -0.18 degree
Rear Cross Camber within 0.50 degree
Z06 (missing in '01) Service Manual Alignment - as written by Hib Halverson
Front Individual Toe: +0.04 degree +/- 0.10 degree
Front Sum Toe : +0.08 degree +/- 0.20 degree
Front Individual Caster: +6.9 degree +/- 0.50 degree
Front Cross Caster: within +/- 0.25 degree
Front Individual Camber: -0.70 degree +/-0.50 degree
Front Cross Camber: within +/-0.25 degree
Rear Individual Toe: -0.01 degree +/- 0.10 degree
Rear Sum Toe: -0.02 degree +/- 0.20 degree
Rear Individual Camber: -0.68 degree +/- 0.50 degree
Rear Cross Camber: within +/- 0.50 degree
Interesting, you make a good case for me to drive down to PA just for them. So did you use the spec's above for alignment and lowering? Or did they give you a spec sheet when done?
