Check Tire pressure system
Old May 6, 2007 | 03:02 AM
RogerArrambide's Avatar
RogerArrambide
Default Check Tire pressure system
This message are deploying, I tried to resync but I couldnt, I use a magnet en the valve but, never change in the dash to the next tire.
If I check gauges, the front are good, the rear, dont show rear left but he show rear right.
Is there a posibility that all the problem is that?
Old May 6, 2007 | 03:05 AM
DeeGee's Avatar
DeeGee
If the TPS is not showing the rear left tire, it sounds like the battery on that sensor has died.
You'll need a new one if so. They're quite pricey and you need to take the tire off to fit it. I'd check the Forum vendors for the best deal.
Old May 6, 2007 | 03:09 AM
RogerArrambide
Thanks a lot
Old May 6, 2007 | 03:11 AM
DeeGee's Avatar
DeeGee
Old May 6, 2007 | 07:01 AM
Check with GMPartsHouse for a new sensor.
Old May 6, 2007 | 07:45 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
with the above comments.
Your profile doesn't indicate the year of your Vette, so it is difficult to know if this is an isolated instance.
I.e., if your Vette is over 5 years old consideration to changing ALL TPS is a good idea
Old May 6, 2007 | 07:48 AM
SlideRulz's Avatar
SlideRulz
I have a 2001 and just had to replace the rear sensors last week.
Old May 6, 2007 | 08:44 AM
Oldvetter's Avatar
Oldvetter
You don't say what year your C5 is in your profile or post ? But, since it has wagon wheels, it is a 1999 or earlier. Most likely your TPSs are going bad, it is about time.
Be sure to get Generation I ones, they are more expensive. I got mine at Fictner's for about $80 apiece.
Good luck.
Old May 6, 2007 | 10:00 AM
jrose7004's Avatar
jrose7004
www.gmpartshouse.com
Old May 6, 2007 | 12:59 PM
RogerArrambide
I still dont refresh my profile.... sorry..
My C5 is 97 but it has 50K miles only.
Old May 7, 2007 | 02:51 AM
DeeGee's Avatar
DeeGee
If they are the original sensors you did quite well. The average life is supposed to be 5-7 years.
Old May 7, 2007 | 05:57 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I had one do the same thing.
To Check Tire pressure system
