Painted calipers
Old May 20, 2007 | 10:00 PM
yaknow's Avatar
yaknow
Originally Posted by drews60
Thanks for the info and pics. This is another job I have to do sooner or later.
Me too
Old Aug 4, 2007 | 04:01 AM
Junkman2008's Avatar
Junkman2008
Originally Posted by Stickman81
I painted mine.
I did use clear on the fronts over two years ago with no issues.
For the letters, I covered them with chapstick. Once the paint dried up I wiped the letters off, then lightly ran a very fine sanding block (foam type) over the letters.
Am I reading your post correctly when you said that you painted the entire rotor? You said that your first braking cleaned off all the paint that needed cleaning, but didn't this foul up your brake pads? I'm curious to know!
Old Aug 4, 2007 | 04:08 AM
DeeGee's Avatar
DeeGee
Originally Posted by rws.1
Rustoleum, Sunrise Red.
Under $4 per pint anywhere, cheapest at Walmart.
Brush it on. 1 pink will give you 4 coats on all 4 calipers and leave plenty for touch ups over the years.
3 years and 15K miles on mine... Have only touched them up this year.
clean with a wire brush and brake cleaner first....
coat the raised letters with chapstick... paint over them. they use a sharp razor blade once you've finished the calipers and the paint on the letters slices right off...
Rustoleum Satin Black no clear.
Old Aug 5, 2007 | 12:14 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
I followed the same procedure.......worked great. Just a reminder, don't put the Chapstick back in your pocket when you're done!
Old Aug 5, 2007 | 12:25 PM
LeeJones's Avatar
LeeJones
From: I saw her today at the reception.....a glass of wine in her hand...
anyone know if mag red paint is produced anywhere?
Old Aug 5, 2007 | 01:14 PM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
I painted mine.
Here is my post from another thread.
What did you use to get the rust off??? I need to do this to my car.
Old Aug 5, 2007 | 03:25 PM
Junkman2008
Elbow grease, wire brushes and brake clean. I'm doing mine right now. I'm doing a very, very detailed write up also. I'll share the fun when I'm done.
