Window Vallet?
Old May 18, 2007 | 04:58 PM
terry621's Avatar
terry621
From: Peterborough"I'd rather be topless than all couped up" Ontario
St. Jude Donor '07-'08-'09-'10
Default Window Vallet?
I love this little thing especially on my vert
QUESTION every once in a while lets says 3-10 times when putting the windows up The windows go up and then right back down and try again same thing unless I open a door
any ideas whats up with That. you guys are the best at this stuff
Thanks in advance and everyone have a GREAT weekend
Old May 18, 2007 | 05:11 PM
dndrsn's Avatar
dndrsn
Recalibrate the windows. You may have to set the window up strength to "strong".
Old May 18, 2007 | 05:12 PM
NCSU SEE 5's Avatar
NCSU SEE 5
From: Greensboro, NC "REALITY IS MERELY AN ILLUSION, ALBEIT A VERY PERSISTENT ONE"...ALBERT EINSTEIN"
St. Jude Donor '05-'06-'07
Mine does that every so often. Not sure what causes it, may be just an electrical quirk. In 3+ years it has happened 5 or 6 times that I know of. Sorry I don't have an exact cause, but you are not alone.
Old May 18, 2007 | 05:35 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I agree - temp changes can cause things to change to the point where you need to recalibrate the windows. If it goes up, then right back down again, its because it assumed that something was blocking the window - this is a safety function. A recalibrate lets it learn where the top of the window is again, and resets how much force it should consider normal.
Old May 18, 2007 | 05:46 PM
02MillenniumVette's Avatar
02MillenniumVette
Old May 18, 2007 | 07:51 PM
2klude's Avatar
2klude
Just wondering... but how does the window actually go down and up, what buttons on the key fob do you hit?
how would you roll up or down the window without locking or unlocking your car if you use the keyfob to control the window valet. There are only so many buttons on the c5 keyfob
Old May 18, 2007 | 07:54 PM
BuckyThreadkiller's Avatar
BuckyThreadkiller
Successful Plumber
From: Top of the hill, 3rd mailbox on the right. Texas
CF NCM Ambassador
CI 6-7-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10
NCM Member '09
Unlock 3 times and the windows drop. Vehicle's open.
Lock 3 times, the windows go up and the vehicle is secure.
Old May 18, 2007 | 10:06 PM
terry621's Avatar
terry621
Default Thanks guys
I will try the re-calibrate Didn't even think of it.
How did we live before this CF..
Old May 18, 2007 | 10:33 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
Life before CF was Much Cheaper. All these mods, so little budget!!!
Old May 18, 2007 | 10:40 PM
Big-Red's Avatar
Big-Red
St. Jude Donor '06-'07-'08-'09-'10,'13-'14
My Window Vallet has never worked for the up position and I suspect it
never will. I will not recalibrate the DIC for this. Given the nature of flex
in the rag top system this could open up a real can of worms.
Old May 18, 2007 | 11:49 PM
BanditDude's Avatar
BanditDude
Mine does this when I haven't driven the car for a while, and the battery is a bit run down. The solution is to just drive the car more.
Old May 19, 2007 | 12:35 AM
DeeGee's Avatar
DeeGee
You live and learn. I've had that problem for a while. I had no idea that affected it.
Old May 19, 2007 | 07:54 AM
Blue260's Avatar
Blue260
[QUOTE=terry621;1560304794]I love this little thing especially on my vert
I can't stand mine. Pain in the butt everytime you want to crack the window - constant pushing, almost like double clicking on a mouse.
Old May 19, 2007 | 08:21 AM
Phanni's Avatar
Phanni
If you don't like it, it is probably the easiest of any mod to remove.
Old May 19, 2007 | 09:47 AM
JohnTheStigGalt's Avatar
JohnTheStigGalt
It's not recalibration of the DIC -- it's recalibration of the WV module. Mine does it about once or twice a month and I've just never bothered to recalibrate it. Anyone got a link to the instructions?
Like Phanni said -- easy to remove, and I'm sure you'd have NO PROBLEM selling it on the forum. I love mine!
Old May 19, 2007 | 09:54 AM
blazeone's Avatar
blazeone
Make sure when you re-cal the valet the door are shut.
Old May 19, 2007 | 09:55 AM
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
This should help. You will need your PIN. Been a while since I've messed around with mine. Haven't had any trouble w/it.
http://www.topdowntech.com/qReference.html
To Window Vallet?
Old May 19, 2007 | 10:09 AM
Jake the Snake's Avatar
Jake the Snake
I love these things and wouldn't be without it on my vert. Not having to get in the car and use the ignition switch to raise or lower the top made it worth the price.
It was a little bit of work to calibrate the first time. I moved it from my 99 to the 02 without recalibrating and it works fine. It is not meant to partially open or close a window, that would take a lot of button pushes!
Old May 19, 2007 | 11:02 AM
DeeGee's Avatar
DeeGee
........ I love mine!
Here you go:
http://www.topdowntech.com/documents/WV-100.pdf
Old May 19, 2007 | 02:14 PM
Mr. Jean's Avatar
Mr. Jean
Love mine, works great.
