Retractable Antenna Woes
Old May 19, 2007 | 05:07 PM
DeeGee's Avatar
DeeGee
Default Retractable Antenna Woes
My retractable antenna on the Vert has started playing up. It stays slightly extended when the radio's turned off
I tried lubing it with silicon grease but its no better yet
Is there anything else to this that I'm missing? I'd have thought it just needed lubrication but anyone had similar snags?
Maybe I'm looking at a new part?
Old May 19, 2007 | 06:12 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Dave, I can't speak from experience on our vert power antennas. But awhile back a Cadillac of mine did just what you describe. I was able to repair it with no parts or money. What had happened was that there was a flexible nylon rod about a 1/16" in diameter that the motor shoved up the shaft tubes had gotten brittle and broken off close to the top end. So when going up it would work fairly well and had enough friction in the tube to drag the telescopic tubes down until the tube friction was more powerful than the nylon rod rubbing inside the tubes keeping the mast from going down all the way. The fix was just jamming the rod all the way up the antenna shaft tubes and crimping (I used a good electrical connector crimper) the top of the smallest tube around the nylon rod after removing the broken stub of the rod from the shaft. Or you could replace it with a new unit from Gene at GM Partshouse.com. I've seen them in the mail order supply rags for $110 It wouldn't surprise me to see Gene beat that price. Let us know what you do.
Old May 19, 2007 | 09:56 PM
1KLRTOY's Avatar
1KLRTOY
Save your antenna with an on off switch, a simple toggle switch from Radio Shack and 20' of 18ga wire is all you need, just cut the pink wire at the antenna and route it through the switch, now the antenna stays down when you play the CD's only goes up when you want it to
Old May 20, 2007 | 01:29 AM
DeeGee's Avatar
DeeGee
Thanks Ed
Looks like a bit of DIY is called for. $110 for an antenna
Maybe I'll check out genes Karshop
Old May 20, 2007 | 08:13 AM
AuburnShrink's Avatar
AuburnShrink
This seems like an excellent idea. Thanks. Anyone else try this?
Where do you put the toggle switch?
Old May 20, 2007 | 01:40 PM
4 GRINS's Avatar
4 GRINS
Default Antenna Bypass
Did this as one of my winter mods (also added an ipod dock). Installed toggle inside the center console at the front. Works well. Send me a pm if you'd like more details.
Old May 20, 2007 | 01:45 PM
dndrsn's Avatar
dndrsn
I just unplugged my antenna. It stays down all the time and I still get reception from all the radio stations that I normally listen to.
Old May 20, 2007 | 04:11 PM
DeeGee's Avatar
DeeGee
Theres a thought
Old May 20, 2007 | 04:22 PM
Big-Red's Avatar
Big-Red
St. Jude Donor '06-'07-'08-'09-'10,'13-'14
I can't understand why GM did not do this a LONG time ago!!
Old May 20, 2007 | 05:29 PM
1KLRTOY's Avatar
1KLRTOY
I routed the wires under the carpeting, under the center console (had to lift up) and mounted it in the ash tray compartment (I removed the ashtray) I just fabed a bracket to mount the switch, works great, antenna up only when needed
Old May 20, 2007 | 07:22 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I had a Bonneville with the same problem. I went to the local dealer and they sold me a replacement nylon part for $25. That was a hole lot less than a new antenna.
Old Aug 27, 2007 | 01:53 PM
bighank's Avatar
bighank
Default Go to antennamastsrus.com less than $20 shipped
They also show you how to do it on their website.
Have fun BIGHANK
Old Aug 27, 2007 | 02:48 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Here you go:
http://forums.corvetteforum.com/show....php?t=1782626
http://forums.corvetteforum.com/show....php?t=1758777
To Retractable Antenna Woes
