Need help hooking up
Old May 21, 2007 | 12:55 AM
Slowvette002's Avatar
Slowvette002
Default Need help hooking up
Just curious if anyone could help me with my suspension issues. Basically anytime I try to hammer down on it from anything less than a 40mph roll, it just takes off sideways and I have to let out. I am looking to upgrade the suspension but I'm not rich so I want to make sure the upgrades I choose are the right ones. What would some of you upgrade first? Shocks? Springs? Sway bars, bushings, etc..? Any help would be great. Thanks
Oh, and just in case any need to know, I run a pretty stock setup. a4, 3.23 gears, aftermarket B&B Exhaust, Varraram Intake, lowered 2" all around on stock bolts, and upgraded tires to 255/45/zr17fronts, 295/35/zr18's back...
Old May 21, 2007 | 01:11 AM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
try a singles bar...
Old May 21, 2007 | 02:54 AM
Slowvette002
lol, ttt
Old May 21, 2007 | 03:38 AM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Tires, get some better compound before you go messing with possibly needless suspension mods.
Old May 22, 2007 | 02:07 AM
Slowvette002
Default ive upgraded the tires
to a better size and better brand. Lets just say tires arent the problem. Then what?
Old May 22, 2007 | 03:18 AM
ptindall's Avatar
ptindall
I don't think the stock bolts will take you down a whole 2". If you are that low, your suspesion geometry may have gotten off. Get a four wheel alignment done and have them look for rear suspension wear or damage. Your car should not be going sideways. There may be a bushing or ball joint that is moving when you apply power to it. I don't think you an upgrade, just a repair. With your setup, you shouldn't even be able to break the tires loose at 40mph, let alone get sideways.
Old May 22, 2007 | 08:34 AM
KARLDDS82's Avatar
KARLDDS82
Old May 22, 2007 | 08:42 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
These will fix up up
http://www.customcorvetteaccessories...tswaybars.html
And a good set of Koni FSD's
Give me a call if you have any questions.
Peace
Chip
__________________
..................Click for
Old May 23, 2007 | 10:59 AM
robert123's Avatar
robert123
323 gears?
Old May 23, 2007 | 11:04 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Stuff a potato in your pants.
Only kidding.
To Need help hooking up
